Bronco II Ford Bronco II
86 Bronco possible alignment issues
Old 03-21-2012, 07:15 PM
jkufen's Avatar
jkufen
jkufen is offline
On my 86 b2 while driving down the road if i want to go straight I have to hold the steering wheel over in the 10 oclock position and if i let go of the wheel it jerks real bad to the right. Is this just a simple alignment issue or is it something else? Thanks!
Old 03-23-2012, 05:11 AM
critterf1's Avatar
critterf1
critterf1 is offline
Sounds like a bad steering gear box.
Old 03-24-2012, 03:14 AM
Mr.Offroad's Avatar
Mr.Offroad
Mr.Offroad is offline
There's actually a few different things that could cause this, a bad powersteering box is one. If you whacked something with one wheel, it could've changed your caster or camber, could be a brake dragging, could be as simple as a broken or slipped belt in a front tire. I'd have an alignment guy at least take a look-see at it. They'll be able to tell you right away what it is.
Ian123
1999 to 2016 Super Duty
07-09-2012 07:32 PM
JethroF250
02-28-2008 04:34 PM
franks_ford
13
09-13-2007 09:58 PM
omni
08-04-2006 11:58 PM
AlM
1978 - 1996 Big Bronco
12-24-2001 09:32 PM
Quick Reply: 86 Bronco possible alignment issues
