just a tad bigger. his is s362 so its pretty close. might be getting larger turbine housing for mine tho, if it turns out a bit small. should be perfect
I'm going to build the engine similar to mine, with this bigger charger, and more fuel.
I'm chopping the frame down, and converting it to short box. mono-beam front axle, 9" in the rear. Tubed, caged... ect. Goal is get it down to 3500lb race weight. Will be backed by a full billet ATS standalone E4OD.
Good Lord this sounds like fun. And i'm with rifleman, can't find any in this shape under 2k here in Ohio. Just a question. If you're going to shorten the frame why not just get a 1/2 ton short bed truck and do a little bracing in the front? Jw. Anyway ya do it it'll be a BAMF though. Good luck.
Didn't want to deal with the gas to diesel conversion stuff, as well as trying to register it that way, washington is weird.
Also, when we went to pick this up, the guy told us it was an 86 F350, so we were expecting a D60 front to sell off to recoup purchase cost.
