I need a set of window washer nozzles for a 2008 f-450. Just the nozzles, I have the hose. The aftermarket ones at the parts store are angled too low for the large hood and window of my truck.
Thanks,
Brian
I could take those.. Mine are clogged. I assume they are the same as for 99-07?
Great idea.
Is this for looking or giving away.
Not sure,I thought I saw a MOD say no looking for parts.Only offering what you have.
I see post with people asking for parts and some offereing????
Looking for bushings for the front sway control bars for an '03 F-250 4x4...
I have those bushings will get them today and take some pics they should be ready to run, I took the swaybar off with my lift kit so they didnt have much use. send me a PM later so I forget.
I am in NEED of a stock Compressor wheel housing just the back plate that goes behind the Wheel.. mine housing is loose around the bearing making the back and front of my Comp. wheel hit the housing.
I have a 05 6.0 does anyone have the retaining bracket and bolt that hold on the vgt solenoid to the turbo it self?
Mine was stolen actually the solenoid and bracket and the bolt was stolen, but I was able to replace the solenoid but it did not come with the bracket and bolt.
