radiator help
radiator help
So i discovered a small hole (about the size of a pea) in my radiator and i dont know how to fix it. i bought Bar's leaks radiator because it says it stops leaks but it says dump it in the radiator with coolant and let it run for 15 - 30 minutes the only problem is that my radiator leaks a lot really fast and i dont know if this will stop the leak i was wonder any opinions
Any idea how much a shop would charge about to do that?
I was going to ask the same question but mine is a 1/4" crack on the top that spits fluid out in small amounts. Im a ebay freak and saw 3 core radiators for $209 and if there is a cheaper easier way of keeping mine till I get money it would be nice. Also don't they do a thing called radiator brazing for holes that big?
trevorrules
17
03-20-2021 08:25 PM
dtgl90vt
15
11-16-2012 08:32 PM
