You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
Guys, im at my witts end with a problem i have been having and could use some help. I have a 2001 hd f150 with 146,000 miles on it. At around 50-60 mph it will buck and jerk very noticeably then continue on like nothing has happened. It has shot out a code which related to camshaft position sensor or crankshaft position sensor(depending on who is reading the code). I have changed both sensors twice and have changed all plugs and coil packs. I reset the light and it comes back on after it bucks and jerks again around 50-60mph. I cant find anything remotely related to what this could be, and any input would be much appreciated. thanks
thanks for the response beechkid I will definitely give that a shot. I was told to check wiring but this is the first time somebody has said that fords have had problems with those connectors.
