Oil Filter - Ford Truck Enthusiasts Forums
Oil Filter
Old 03-21-2012, 08:16 AM
BURNSTOUGHFORD's Avatar
BURNSTOUGHFORD BURNSTOUGHFORD is offline
BURNSTOUGHFORD has a good reputation on FTE.BURNSTOUGHFORD has a good reputation on FTE.
Oil Filter
I have been having a heck of a time finding the Part number for a moto craft oil filter for my 1993 Bronco 5.8. I have the fram number, but dont want to use one on it.
Anybody help me out? BTW ford's motocraft site is messed up, when through there process only for it to tell me they didnt have anything that matched my criteria.
Anyways. Help would be appreciated.
Old 03-21-2012, 09:01 AM
Joseph69's Avatar
Joseph69 Joseph69 is offline
Joseph69 is starting off with a positive reputation.
Doesn't it take the FL1A like the older ones?
Old 03-21-2012, 10:40 AM
Hizootiemizark Hizootiemizark is offline
Hizootiemizark is starting off with a positive reputation.
Yep I think it should be the FL1A get mine at Wal Mart
Old 03-21-2012, 11:22 AM
Big_Rob's Avatar
Big_Rob Big_Rob is offline
Big_Rob is gaining momentum as a positive member of FTE.
you can find it here...
Official Ford Parts Site | Buy Motorcraft & OEM Ford Parts Online | FordParts.com
great OE parts search tool.... just enter your VIN.... my 5.8 filter is 6731 (FL-820)
Old 03-21-2012, 11:37 AM
Big_Rob, I dont have my vin on hand. Obiviously i could go read it. But for some reason when i enter 1993 Bronco 5.8l it tells me no parts match my criteria.
Any ways. Now we have conflicting filters...
FL-820
or
FL1A
Old 03-21-2012, 11:51 AM
Big_Rob's Avatar
FL-820
or
FL1A
I don't think much changed from 93 to 94 like mine. I just ran the 93 on that site and I get the same error. But if you change the year to 94 5.8 you will get the result.
Old 03-21-2012, 12:05 PM
Kemicalburns's Avatar
Kemicalburns Kemicalburns is offline
Kemicalburns has a great reputation on FTE.Kemicalburns has a great reputation on FTE.Kemicalburns has a great reputation on FTE.Kemicalburns has a great reputation on FTE.
yes there is a difference. in 94 the 5.8 got the oil cooler which uses a different filter then the previous years. I run purolator filters and for your 93 i think it should be a
P30001.
Old 03-21-2012, 12:53 PM
b4hntn b4hntn is offline
b4hntn is gaining momentum as a positive member of FTE.b4hntn is gaining momentum as a positive member of FTE.
IF you have the oil cooler between the filter and the block it will have two small hoses going to the lower radiator hose. IF so you need the shorter filter FL-820SL if my memory is correct.
If not go with the FL-1A
Old 03-21-2012, 06:13 PM
Big_Rob's Avatar
Well if you weren't sure before, now should be completely unsure
Old 03-22-2012, 12:46 AM
greystreak92's Avatar
greystreak92 greystreak92 is offline
greystreak92 has a great reputation on FTE.greystreak92 has a great reputation on FTE.greystreak92 has a great reputation on FTE.greystreak92 has a great reputation on FTE.greystreak92 has a great reputation on FTE.
FL1A...
300 - FL1A
302 - FL1A
351W - FL1A
351m - FL1A
400m - FL1A
460 -FL1A
...and just about every other Ford mill from the mid sixties through the advent of the modular engines near the turn of the century. If you want someone else's P/N for it just cross reference it against the OEM (Motorcraft) FL1A. The ONLY reason the FL820 was used was so that the added depth of the oil cooler ring would not make the oil filter protrude further from the block than the FL1A did without the cooler fitting behind it. The FL820 is physically shorter than the FL1A but otherwise the same. The FL1A can still be used on vehicles with the oil cooler if you can get in in place.
Old 03-24-2012, 10:08 PM
igotoneforya's Avatar
igotoneforya igotoneforya is offline
igotoneforya is starting off with a positive reputation.
FL-820S for 94 ( some)and up
My 94 5.8 and the excursion use the same one...
The difference is threads/hole diameter. New ones use the metric 820s with silicone valve for anti drain back. They are not interchangeable.
93 should use the FL1A.
Old 03-24-2012, 11:04 PM
Ok then... guess I have the P/N wrong because there is a "short version" of the FL1A with a different number. I still question the validity of this. There would have been no reason to change filter types in 94. The engines didn't change. Why would the filter change?
Old 03-25-2012, 06:53 AM
My 94 5.8 had the short filter when I bought it. I measured the length then went to a parts store and measured the FL1A . I decided the FL1A might fit if you did not need room to screw it on and off. I did not know the threads/holes are different. My 94 has the towing package which included the oil cooler under the filter.
Old 03-25-2012, 02:04 PM
supposedly it is a metric/SAE thing...and supposedly the 820s anti-drainback helps with dry oil-less starting...
http://www.ford-trucks.com/forums/88...he-fl-1-a.html
and
http://www.ford-trucks.com/forums/87...s-fl-820s.html
these are from our site and give more info if interested.
What filters (with part numbers) are you guys using? Big-Foot 6.7L Power Stroke Diesel 10 11-28-2015 09:49 AM
so guessing international gave me wrong oil filter TAT2DUP81 6.0L Power Stroke Diesel 11 06-25-2011 09:28 PM
Educate me on Oil Filters..... Fallguy2004 6.0L Power Stroke Diesel 53 11-07-2010 04:42 PM
4.2L V6 - Plugs, fuel filter and oil weight recommendation iirnited 3.8 & 4.2L V6 11 04-21-2009 12:37 PM
1950 Ford 226 Flat 6 Oil Filter Christopher2 1948 - 1956 F1, F100 & Larger F-Series Trucks 9 05-17-2005 08:24 PM
Tags
1978, 1994, 460, 58, 94, bronco, change, filter, fl1a, ford, oil, room, special
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
