2002 F150 Wiring Diagram NEEDED
02 f-150 4.6 supercrew 2wd xlt auto
Replaced the heater core, reassembled dash, forgot two plugs to the instrument cluster, removed necessary items, replaced plugs and reassembled the dash to factory specs. Attempt to START= starter engaged normal speed/no start. Ignition in the ON position = Gauges do not clock over/indicators DO function. Theft light is NO different than pre-H.C. replacement. Possible PATS ?? (removed ignition tumbler to remove column cover) reinstalled. All fuses in the underhood and dash are good.
I would like direction to a wiring diagram for the ignition system/fuel system/instrument cluster-pin locations/funtions and If there is anyone with information or a diagram regarding the Ford Vehicle Security used as an alarm piggybacking the factory keyless entry system, I need the functions and possible programming info.
Hey Locksmith1 - I have an 2003 F150. Is it possible you can share me the wiring diagrams you have. I have a weird problem that started after installing a remote starter. Any information would be greatly appreaciated. I'm the original owner and plan on keep my truck for a long, long time. Thanks. Dan
yes.. mainly the starting system and any information on the PATS system if you have. Thanks: phyrelizard@yahoo.com
