97 F150 Overheating
Old 04-28-2003, 09:04 AM
emilearl's Avatar
emilearl
emilearl is offline
Angry 97 F150 Overheating
My 97 F150, 4.2 V6, is overheating. I have coolant. When I turn on the heat in the cab, the engine will cool down. I took it to the shop. They replace the thermostat and the timeing cover which was cracked. This did not solve the problem. If I run with the heat on it runs fine. When I turn the heat off the temperature gauge goes to Hot. Help
Old 04-28-2003, 12:16 PM
f150-az's Avatar
f150-az
f150-az is offline
97 F150 Overheating
There's two possible things I can think of. First off, your water pump might not be working and second, you might just need to flush your radiator out since it might be a little clogged.
Old 04-28-2003, 07:31 PM
Racerguy's Avatar
Racerguy
Racerguy is offline
97 F150 Overheating
Hi emilearl and welcome to FTE
I think that f150-az is on the right track with the plugged rad. Might want to flush the cooling system and see what happens.
Old 04-28-2003, 11:50 PM
dave2002's Avatar
dave2002
dave2002 is offline
97 F150 Overheating
I have a similar situation. Shop said my timing cover broke because it might have been cracked. He broke it. It still overheats. The waterpump timingchain and gears were also changed. Then they said to check the radiator. Im taking it to a different shop tomorrow to check the intake gaskets.
Old 04-29-2003, 07:52 AM
emilearl's Avatar
emilearl
emilearl is offline
Smile 97 F150 Overheating
Thanks guys for the tip on flushing the radiator. I am having that done now. I will let you know how it works.
emilearl
Old 05-15-2003, 08:36 PM
dave2002's Avatar
dave2002
dave2002 is offline
Thumbs up 97 F150 Overheating
I had my radiator rodded out today. The guy at the shop said it needed it. After over heating the mold clay left in the radiator from the factory loosens , collects and clogs the radiator. Overheating is not my problem now.
Dave
Old 05-16-2003, 03:43 AM
wmcnally's Avatar
wmcnally
wmcnally is offline
97 F150 Overheating
emilearl,
<<They replace the thermostat and the timeing cover which was cracked.>>
Cracked timing cover ??Could?? mean you have "oil in your coolant"(overheating) and "coolant in your oil"(goodbye engine)
CHANGE your OIL and CHANGE your COOLANT!!
Old 05-16-2003, 08:57 AM
emilearl's Avatar
emilearl
emilearl is offline
97 F150 Overheating
Cracked timing cover was replaced. I found out I had poor flow through the radiator.
sirblast
6.7L Power Stroke Diesel
11-18-2017 05:07 PM
petrvan
28
01-27-2016 08:41 PM
fordka
09-28-2014 01:12 PM
sleepyNseattle
29
01-16-2012 07:01 AM
drewsky
2004 - 2008 F150
08-28-2010 08:11 AM
Quick Reply: 97 F150 Overheating
