97 F150 Overheating
97 F150 Overheating
My 97 F150, 4.2 V6, is overheating. I have coolant. When I turn on the heat in the cab, the engine will cool down. I took it to the shop. They replace the thermostat and the timeing cover which was cracked. This did not solve the problem. If I run with the heat on it runs fine. When I turn the heat off the temperature gauge goes to Hot. Help
97 F150 Overheating
I have a similar situation. Shop said my timing cover broke because it might have been cracked. He broke it. It still overheats. The waterpump timingchain and gears were also changed. Then they said to check the radiator. Im taking it to a different shop tomorrow to check the intake gaskets.
petrvan
28
01-27-2016 08:41 PM
fordka
09-28-2014 01:12 PM
sleepyNseattle
29
01-16-2012 07:01 AM
150, 1997, 1999, 2000, 42, 97, econoline, f150, ford, heating, intermittent, overheating, problem, replace, thermostat
