Newbie Help: 1995 F-150, dashboard light
Am the newly minted owner of a not so new but great '95 F-150. No Owner's Manual. Recently the dashboard lights went out (either that or I did something to switch them off) and i miss that deep phosphorescent green. How do I fix this, where do I find the bulb, etc. THe warning lights work, but not the rest of teh dashboard.
Thanks in advance.
Thanks in advance.
Turn the headlight **** counter clockwise till it stops to see if it is the bulbs or not. If you turn it to far the dome light will come on.
Also check the fuse panel for Inst fuse I think its 15 amp
Hope this helps
Gasman
Do you have Gas?
Propane Execeptional Energy
Hope this helps
Gasman
Do you have Gas?
Shosha13
1997 - 2003 F150
11-02-2008 11:43 AM
