Go Back   Ford Truck Enthusiasts Forums > Older, Classic & Antique Trucks > 1948 - 1956 F1, F100 & Larger F-Series Trucks
Sign in using an external account
Register Forgot Password?
Welcome to Ford-Trucks Forums!
Welcome to Ford-Trucks.com.
You are currently viewing our forums as a guest, which gives you limited access to view most discussions and access our other features. By joining our community you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is fast, simple and absolutely free so please, join the Ford-Trucks Forums community today!
  #1 (permalink)
Old 03-20-2012, 01:13 PM
Gwilkrrs Gwilkrrs is offline
Gwilkrrs is starting off with a positive reputation.
hidden door hinges
has anyone removed the stock door hinges and installed hidden hinges to get the modern door clean look? what hinge kit and where did you get it from?
thinking about this for a 51 f1
  #2 (permalink)
Old 03-20-2012, 04:30 PM
48 Steel's Avatar
48 Steel 48 Steel is offline
48 Steel has a good reputation on FTE.48 Steel has a good reputation on FTE.48 Steel has a good reputation on FTE.
I did and this is where I got them. NOTE: if you buy this kit they tell you to use a steel rod to hold the hinges in line. What they forgot to tell their customers was that the rod is "allthread" rod not smooth rod. Let me know if you decide on these and I can assist you on questions.
Heavy Duty hidden hinge kit Deluxe hidden hinge kit Super Hinge
____________________________________________
46 Ford Super Deluxe Tudor - Street Rod
48 Ford F1 - Darkside
"Happiness - 3 pedals and a 5 speed"
  #3 (permalink)
Old 03-21-2012, 05:55 AM
thanks! thats what i was looking for. was it diffulcult to install? is the support in the door adequate? i am in the planning-purchase and store state but not install state right now
  #4 (permalink)
Old 03-21-2012, 07:40 AM
48 Steel's Avatar
If you check in my Gallery you will find pictures of my installation. I think that the install went well and I did have to return the original order due to the hinges being too big to fit the post. But the small hinges fit just fine.
  #5 (permalink)
Old 03-21-2012, 11:42 PM
52 Merc's Avatar
52 Merc 52 Merc is offline
52 Merc is a name known to all52 Merc is a name known to all52 Merc is a name known to all52 Merc is a name known to all52 Merc is a name known to all52 Merc is a name known to all
A better setup is the kit from Hagan. It has better adjustability, but the best and most important part to me is the built in check mechanism. It helps hold the door open and doesn't allow it to flop around or fly open without something to help catch it. It's more like a real car door hinge than one from a barn door. It's a couple extra bucks, but well worth it, imho.
Hagan Street Rods
__________________
Wayne
52 Mercury M-1
among other things.
  #6 (permalink)
Old 03-22-2012, 01:18 PM
these are the kits i was thinking about----- 1 question is---- are you able to put a fabrich door panel over the hinge? i dont know for sure but i think i will have full interior.........
  #7 (permalink)
Old 03-22-2012, 07:54 PM
MrMach71's Avatar
MrMach71 MrMach71 is offline
MrMach71 is starting off with a positive reputation.
any pictures????
  #8 (permalink)
Old 03-22-2012, 09:40 PM
52 Merc's Avatar
Quote:
Yes. You have to cut a notch in the door shell and weld in the rectangular U shaped plate, which will create a pocket for the hinge to bolt into. It will be below the inner skin when finished if you do it right. You can cover the entire inside of the door and no one will ever see it.
__________________
Wayne
52 Mercury M-1
among other things.
  #9 (permalink)
Old 03-23-2012, 11:22 AM
gotcha! thanks! i am leaning towars this as i like the clean look. now to ponder on the side mirrors since the swan's wont work without the hinges.....
  #10 (permalink)
Old 07-13-2014, 01:08 PM
stoneyb12 stoneyb12 is offline
stoneyb12 is starting off with a positive reputation.
Hidden hinge install
Thinking about doing the same with my 52 F1....question...do you have pics of the installation?
what about clearances inside for the window and regulator?
Thanks for any insights
Tags
1952, 51, a, door, doors, f1, ford, hagan, hidden, hinge, hinges, installing, model, pickup, truck, trucks
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2014, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
Advertising - Terms of Use - Privacy Statement - Jobs
vbulletin Admin Backup
