seafoam for a 460
seafoam for a 460
i want to seafoam the 460 engine in my '97 f-supter duty. it *seems* to work well for others. most write-ups i see on it say to pour it into the brake booster line so it distributes evenly to all cylinders. i dont have a vacuum booste line b/c of the hydroboost; right?
what other vacuum line would distribute to all cylinders?. it seems it woud be hard to pour it into the throttle body b/c it doesnt open to the top, but to the front.
any advice?
any advice?
on
You can use it on most all vacuum lines. But you dont pour it into the lines, you stick the line in the can and let it suck it up. Dont let the engine die.
It's much easier and less messy to use a small hose and momentarily dip it into the can - let the engine vacuum do the work for you. You control how much goes in at once by how long you let the hose draw liquid. Not rocket science.
I did the same as trapperjack and poured it in the gas tank. I read in some posts here that it would help pass inspection. I drove the truck using the tank in which I had placed the seafoam until I only had a quarter of a tank than had it inspected. It barely passed and I attribute this to the foam.
Putting the seafoam in the gas tank will clean injectors and fuel system.
Sucking it through the booster hose slowly is what I usually do, but you can stall the motor easy if it goes only into one cylinder like mentioned before.
Find a vacuum line that's common to all cylinder to use. I've stuck the line into the bottom of a funnel as well. It works well when using a short and small line. I've never had a car or truck stall that way.
Sucking it into the engine with vacuum line will clean the carbon off the valves and pistons better.
On a side note.
All my speed density vehicles (as well as all the school busses I've worked on) typically get a healthy dose of the garden hose while revved at 3k. Mist it in... Don't choke it.
Works awesome to clean out the buildup.
On a side note.
