Go Back   Ford Truck Enthusiasts Forums > Older, Classic & Antique Trucks > 1957 - 1960 F100 & Larger F-Series Trucks
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 03-20-2012, 12:30 AM
GB SISSON's Avatar
GB SISSON GB SISSON is offline
Garage is empty, add now
GB SISSON is gaining momentum as a positive member of FTE.GB SISSON is gaining momentum as a positive member of FTE.
Fridge Radiators
Not sure if I'll use an original type or adapt something maybe bigger for the diesel, but I read here at one time that the f350 radiator was bigger than the f100 and 250. Mine didn't come with a rad in it so I used one from a landcruiser for the 223 as a temp. PO did toss one on the bed for me but he wasnt sure where it was from and it's separated bad form the tanks. The radiator I need would have the bottom neck on the left side. Are the v8s on the left? I might hit some junkyards off island on Wed, so maybe I can make some calls tomorrow if I get some info. Thanks, GB
__________________
'92 F350 4x4 dual wheel service truck. 7.3 with headers and glass packs. 5 sp man tran. 255 85 16 Toyos. 110,000 miles. '59 F350 9' flareside new project, cummins 6at turbo diesel, sm 465 4 spd. 255 85 16s again, 37 ford 1 1/2 ton stake with 53 flathead V8. 65 toyota landcruiser fj 45 longbed pickup. 54 GMC 3/4 ton flatbed w/ cummins 6at, '68 BSA 441 Victor Special, bone stock, Antique tractors and one lung flywheel engines .....
  #2 (permalink)
Old 03-20-2012, 08:55 AM
F250racer's Avatar
F250racer F250racer is offline
F250racer is starting off with a positive reputation.
yea the 292's had the bottom on the left(drivers) and the top hose in the center. The f350's did come with larger ones than the smaller trucks, i'm not sure how much of a difference there is though. I'd just find one that's kind of close and make it work.
__________________
Colin
'59 F-250 Styleside Longbed, 292, 4spd, Rockwell 5.83 dually running gear, custom NP205 overdrive.
"The truck's a Ford and the tractor's green"
Tags
12, 1972, ford, radiator, ton
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
