1970 F250 4x4 Cummins Conversion Build Thread - Lots of Pics! - Ford Truck Enthusiasts Forums
Old 03-20-2012, 01:24 AM
ryanhablitzel's Avatar
ryanhablitzel ryanhablitzel is offline
ryanhablitzel is starting off with a positive reputation.
Let the journey begin! This started as a “budget” project, but we all know how that goes.
Picked up a 1970 F250 4x4 for $1200. It took the 300 mile drive home with no problems!
Plans for the build:
Suspension (10” Lift)
Front: 6.5” Pro Comp Super Duty lift springs with 4” custom drop hanger
Rear: 64” Chevy rear springs with shackle flip
Wheel base shortened
Axles
Dana 60 front from a 1979 F350
14 bolt rear
Tires
41.5” Pitbull Rocker Radials
Drivetrain
1994-1998.5 Cummins
NV4500 5 speed transmission
NP205 Transfer Case
AND MUCH MUCH MORE!
Dana 60 Front is in the House!
These gears are coming out and a detroit air locker is going in!
Picked up this axle for $2700. It had been completely rebuilt but the guy went a different direction with his project. High steer arms already installed.
Interior is stripped. What do you think of the bull bar? Picked it up at a local auto parts store for $75. It is for a cherokee... but will work nicely on this truck.
Truck is naked
Well we will see how this project goes. The only thing stopping me now is the almighty dollar
Old 03-20-2012, 01:43 AM
401477534 401477534 is offline
401477534 is starting off with a positive reputation.
Freaking awesome, keep us posted
Old 03-20-2012, 06:51 AM
crazed87bronco's Avatar
crazed87bronco crazed87bronco is offline
crazed87bronco is gaining momentum as a positive member of FTE.
Subscribed great build you will be doing exactly what I'm in the middle of doing on my 71 crew cab 8" super duty springs front and rear Dana 60 front Dana 80 or sterling rear custom drop front crossmember cummins and nv4500 got the front suspension on now I'm getting ready to drop the cummins and nv4500 in so I can put in and level up the rear suspension keep the pics coming
Old 03-20-2012, 07:14 AM
KingBigJoe's Avatar
KingBigJoe KingBigJoe is offline
KingBigJoe has a superb reputationKingBigJoe has a superb reputationKingBigJoe has a superb reputationKingBigJoe has a superb reputationKingBigJoe has a superb reputationKingBigJoe has a superb reputationKingBigJoe has a superb reputationKingBigJoe has a superb reputationKingBigJoe has a superb reputationKingBigJoe has a superb reputationKingBigJoe has a superb reputation
Neat project so far. Subscribed !
Old 03-21-2012, 11:11 AM
scottfreeman's Avatar
scottfreeman scottfreeman is offline
scottfreeman is starting off with a positive reputation.
Nice!
Looks good to me. Subscribed.
Old 03-21-2012, 10:52 PM
Ford_Six's Avatar
Ford_Six Ford_Six is offline
Ford_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputation
Good to see another diesel bump. Looks like a nice start and a nice project.
Old 03-27-2012, 04:45 PM
78fordwheelin 78fordwheelin is offline
78fordwheelin is starting off with a positive reputation.
cummins + ford. doesnt get any better than that.
Old 03-28-2012, 05:17 PM
This is what happens when you try to do a BIG job with little tools
But luckily I have cool neighbors with BIG toys! Went ahead and pulled the motor at the same time.
Let the gutless gas hog say hello to ebay!
Everything is back to normal
Old 03-28-2012, 10:52 PM
That sucks same thing happen to me with my crew cab was stripped down like yours was except mine already had the motor out when it fell it was hell trying to lift it back up when I only had 1 jack to use to lift it back up
Old 03-30-2012, 12:28 AM
brobrad's Avatar
brobrad brobrad is offline
brobrad is starting off with a positive reputation.
Working on 69 crew
Looks awesome so far. I'm not interested in all of that sky, but they do look awesome. I'll follow and see how it goes. I've got a long way to go with mine and yep it is the almighty dollar that gets in the way.
Old 03-30-2012, 07:57 AM
hivewax's Avatar
hivewax hivewax is offline
hivewax is starting off with a positive reputation.
I'm also looking to drop a early 12V 6BT Cummins in a '68 F250 4x4 Crew... not sure to buy a new crate motor or donor truck. Looking forward to your progress.
Old 03-30-2012, 10:07 AM
smitty3215 smitty3215 is offline
smitty3215 is starting off with a positive reputation.
if i were you hivewax i would get a donor truck i did this on a superduty and am now doing a 72 crew the donor is the way to go it still will be aroud 6000.00 to 15000.00 to do the swap depending on what you do.
Old 03-30-2012, 10:35 AM
smitty3215 has the right idea. Buy a entire doner truck. That way you can pull everything you may need including fan, radiator, alternator, ac compressor, etc. If you get a truck with the transmission you want also, then that will save you money adapting things. Once you have taken everything you want off the truck, part out the rest and scrap the metal. If you play your cards right, you will have a conversion set up for not that much $$$.
I am still working on finding a doner truck myself. I let a 1996 with 150K miles and a 5 speed slip away a month or so ago. OOops! Spent my money on the axle Now I have to build up the piggy bank again.
Old 03-30-2012, 06:46 PM
brobrad's Avatar
budget
Quote:
I'm shooting for 6000 on mine if i stay on budget. I'm sure it will end closer to 7k. I've got 3k in it right now.
Old 04-01-2012, 06:08 PM
highntight's Avatar
highntight highntight is offline
highntight has a great reputation on FTE.highntight has a great reputation on FTE.highntight has a great reputation on FTE.highntight has a great reputation on FTE.highntight has a great reputation on FTE.
great build keep the pics commin
Lifting my 1979 F150 thread, with lots of pics 460 FORD MAN Offroad & 4x4 1133 04-24-2014 12:41 PM
Lifting my 1979 F150 thread, with lots of pics 460 FORD MAN 1973 - 1979 F-100 & Larger F-Series Trucks 405 07-17-2013 03:59 PM
ch-ch-ch-changes 96sherm Manitoba / Saskatchewan Chapter 116 02-16-2013 05:24 PM
1979 F350 4x4 Find ryanhablitzel 1973 - 1979 F-100 & Larger F-Series Trucks 9 12-13-2012 02:58 AM
The Cooter Chronicles...Beware, Parts Porn! Cooter55 1948 - 1956 F1, F100 & Larger F-Series Trucks 29 08-19-2011 07:44 AM
Tags
1970, 1970s, 4x4, 59l, bronco, conversion, cummins, f100, f250, florida, ford, pics, swap, truck, trucks
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
