1970 F250 4x4 Cummins Conversion Build Thread - Lots of Pics! - Page 3 - Ford Truck Enthusiasts Forums
  #31
Old 05-12-2012, 03:54 PM
koch26 koch26 is offline
koch26 is starting off with a positive reputation.
Great build I can't wait to see morr
  #32
Old 05-13-2012, 04:17 PM
limeyellowfellow limeyellowfellow is offline
limeyellowfellow is starting off with a positive reputation.
Sorry to get off track, how do you subscribe to a thread? I'm looking at adding a diesel as well.
  #33
Old 05-13-2012, 04:19 PM
1972RedNeck's Avatar
1972RedNeck 1972RedNeck is offline
1972RedNeck has a good reputation on FTE.1972RedNeck has a good reputation on FTE.
Quote:
You just did.
I just did too.
  #34
Old 05-13-2012, 07:35 PM
ryanhablitzel's Avatar
ryanhablitzel ryanhablitzel is offline
ryanhablitzel is starting off with a positive reputation.
I mocked up the 1985 Chevy 4x4 hangers and 2002 Chevy springs to see what kind of lift this set up would provide. Here is what it looks things look like loosely put together:
Looks like this set up will give about 5" of lift over the stock set up. I was actually surprised that there was not a lot more.
Measurement with the stock set up loosely put on:
Since I am going to need a little more lift to match what I am doing up front, I am going to have to buy a pair of lift springs to raise things up a little more. I am looking at BDS part #001559 Chevy 5.5" lift springs. These are for a 1/2 ton and should still be pretty flexy. I can get two delivered for about $450.
  #35
Old 05-13-2012, 07:59 PM
Gas Tank Suggestions?
Anyone have suggestions on extra capacity gas tanks? I am ditching the in cab tank and want to install one between the frame. I was thinking about going with one from LMC:
It is a 38 gallon and I can get a brand new sending unit to go with it. It is for a 73-79 Truck, but since I am moving cross members in the rear anyway it looks like it slide right in. Runs about $260 with a new sending unit.
Other suggestions?
  #36
Old 05-13-2012, 08:52 PM
Ford_Six's Avatar
Ford_Six Ford_Six is offline
Ford_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputation
That tank is a bit wide since the later frame is wider. It'll take extra work to get it in there.
Also, make sure the rear springs are up to the task. A leaf spring both suspends and locates the axle, so a really flexy leaf will let the axle move under power. If you want tons of power and flex, go for a multilink with coils or coilovers. This axlewrap issue is one of the reasons for the migration from quarter-elliptical to full multilink setups in smaller rigs, besides the increase in multilink options. My personal favorite is the classic three link, but a triangulated four or a properly done five will give you much more flex.
Another intermediate option is traction bars/links, if you make them about the same length as the rear section of the driveshaft they'll work decently, but you will lose flex.
I just know that even with good springs in my F250, I'm having horrific axlewrap issues with the diesel power. Since I'm running 2wd, it's going to get bars for the time being, but the next truck will be a multilink from the ground up.
  #37
Old 05-13-2012, 10:53 PM
Thanks for the heads up on the 73-79 gas tank. So, basically I would have to grind down my frame to make this fit. Not a great option then. Anyone else have any solutions for a 40-50+ gallon gas tank for a 67-72 highboy? I haven't found one short of fabricating my own.
I had planned on doing a traction bar/link set up on this truck. Since this is my first 4x4 build, I am trying to keep things as simple as possible within reason. Someday it would be nice to do a 3 link on a custom frame rock crawler with a narrowed front clip, but I will save that for another day.
The goal for this truck is to strike a balance between towing, off road capability, and power/fuel economy.
  #38
Old 05-14-2012, 03:31 PM
crazed87bronco's Avatar
crazed87bronco crazed87bronco is offline
crazed87bronco is gaining momentum as a positive member of FTE.
i think ill be putting in a mustang fuel tank in between my rear rails where the spare tire should go from what i see it should just be a matter of moving the crossmember back some and build a frame for the gas tank to sit in. what are you doing for your engine mounts for the cummins? are you going to use the poly bushings if so what size? or what i'm trying to decide what kind of setup i want or mine im at the point now where ill be welding up some mounts looking for ideas
  #39
Old 05-15-2012, 12:45 AM
Quote:
I can't say for sure regarding the motor mounts yet until I have the motor hanging between the frame rails and take a serious look at everything. I have seen guys do a couple of different things. Some modify the stock dodge motor mounts and others build motor mounts from scratch.
I had the same idea regarding the location of the gas tank. I am just trying to find a tank that can hold 40-50 gallons of gas. I may have to take another serious look at the 73-79 extra capacity tank from LMC.
  #40
Old 05-15-2012, 01:34 AM
Have you looked into the long square shaped gas tanks that run longways down the side of the truck? I don't think you will find many tanks with the capacity your wanting without hacking into the tank to make it work what about using a early mustang tank fits between frame rails doesn't have the capacity you want but maybe you can fab one in front of the other not sure if your truck is long enough or not to do that though something to think about
  #41
Old 05-16-2012, 07:01 PM
A 40 gallon tank from a late 70's/80's/90's suburban works great.
  #42
Old 05-16-2012, 07:49 PM
Quote:
Thanks for the imput! I was just starting to consider this option. My friend down the street has a 50 gallon suburban tank in his 80's chevy truck that I was going to take a look at. I will measure things up and see how it all comes together.
  #43
Old 05-16-2012, 11:23 PM
Be sure to post what you find out I want to eventually just run fuel tanks under the truck and get rid of the in cab tank but I want more then 19 gallon or whatever the mustang tanks hold a 50 gallon would be nice
  #44
Old 05-18-2012, 01:58 PM
Measured my friends suburban gas tank in his mid 80's chevy truck today. Its 28"!!! That means that it will fit nicely between the frame rails on a 1967-1972 Ford after moving the cross member!!! He thought it was a 50 gallon gas tank, but all I can find is 31 gallon gas tanks for 1982-1991 Suburban. But 31 gallons is a whole lot better than 18!!!
Here is a good option that I found:
MTS COMPANY, L.C. - Plastic fuel tanks for Jeep, Ford, Chevy, Scout, ******, and Toyota
They offer a diesel sending unit to match. Not sure if that would make a difference.
Another option would be to grab one at pick and pull or find a cheaper new steel version online. I will definitely be using this type of gas tank, but I am not sure what option I will go with yet. I will document this when the time comes.
  #45
Old 05-18-2012, 03:52 PM
Summit racing has '82 to '91 40 gallon tanks. If you're going off road, the 31 will be better as it doesn't hang as low. The 25 gallon tank in my cummins will take me 450 miles.
The Cooter Chronicles...Beware, Parts Porn! Cooter55 1948 - 1956 F1, F100 & Larger F-Series Trucks 29 08-19-2011 07:44 AM
The Cooter Chronicles...an Update Cooter55 1948 - 1956 F1, F100 & Larger F-Series Trucks 19 05-23-2011 01:17 PM
Pics of my 1978 F100 Nick_Good 1973 - 1979 F-100 & Larger F-Series Trucks 5 04-30-2011 06:31 PM
my baby got a face lift joe f350 N. California Chapter 25 12-12-2010 08:15 PM
Blacks turbo rework 67nukeford Nebraska Chapter 17 02-24-2009 10:12 AM
Tags
1970, 1970s, 4x4, 59l, bronco, conversion, cummins, f100, f250, florida, ford, pics, swap, truck, trucks
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
