How much oil should I use in this oil pan
I put a 460 in a 79 ford and had to buy a rear sump oil pan to clear the crossmember. I bought the pan from a guy and dont know what it came off of or how much oil to use. I only see 1 spot with number on the pan and that is in the pic below. Does anybody know how much oil should be used with this oil pan?
I put 6 quarts in my engine and ran it to circulate everything and make sure the filter was totally full. Then tried the 351m dipstick and it didn't even touch the oil. So I just cut the tube off until the oil level was on the full mark. lol. Hey it worked. Now hopefully its not supposed to be a 7 quart pan! I'm pretty sure its not though.
I got this from all-data. I would say these are about the only sources for a rear sump pan.
<TABLE border=0 cellSpacing=0 cellPadding=5 width="100%"><TBODY><TR><TD>1982 Ford Truck E 350 Van V8-460 7.5L
</TD></TR></TBODY></TABLE><!--Start of breadcrumbs--><TABLE border=0 cellSpacing=0 cellPadding=0 width="100%"><TBODY><TR><TD><TABLE border=1 cellSpacing=0 borderColor=#336699 cellPadding=2><TBODY><TR><TD>Vehicle Level Specifications Capacity Specifications Engine Oil </TD></TR></TBODY></TABLE></TD></TR><TR><TD height=10></TD></TR></TBODY></TABLE><!--End of breadcrumbs--><TABLE border=0 cellSpacing=0 cellPadding=0 width="100%"><TBODY><TR><TD vAlign=top align=middle><TABLE border=0 cellSpacing=5 cellPadding=0 width="90%"><TBODY><TR><TD bgColor=#336699 align=middle>Engine Oil</TD></TR><TR><TD align=right></TD></TR></TBODY></TABLE></TD></TR><TR><TD vAlign=top align=middle><TABLE border=0 cellSpacing=10 cellPadding=0 width="90%"><TBODY><TR><TD><TABLE border=0 cellSpacing=1 cellPadding=1 width="100%"><TBODY><TR><TD height=1 vAlign=top>Engine oil capacity </TD><TD height=1 vAlign=top>5.0 Qts.(4.7L)</TD></TR></TBODY></TABLE>Note: Add 1 Qt. with filter change.
<TABLE border=0 cellSpacing=0 cellPadding=5 width="100%"><TBODY><TR><TD>1983 Ford Truck F 350 4WD Pickup V8-460 7.5L
</TD></TR></TBODY></TABLE></TD></TR></TBODY></TABLE>
1996 Ford Truck F 350 4WD Pickup V8-460 7.5L
Engine Oil
Engine Oil
With Filter Change 5.7L (6.0 Qt)
NOTE: Listed capacities are approximate. Check fluid level after filling.
Engine Oil
Engine Oil
