1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
How To Remove The Rear Seat of a 2012 F-350
Old 03-19-2012, 10:32 PM
ZEALOUS_DRAGON's Avatar
ZEALOUS_DRAGON
ZEALOUS_DRAGON is offline
Question How To Remove The Rear Seat of a 2012 F-350
Trying to remove the rear seat from a 2012 F-350 Crew Cab Lariat with factory sub. I removed the 3x bolts from the front and the 3x nuts from the rear all at the floor level. I also removed the center seat belt as well. But for what ever reason it still acts like there is something still hooked up in the center rear area. I cant see any more bolts or nuts. Anyone know how to get this seat out?
Old 03-20-2012, 05:33 AM
2000silverbullet's Avatar
2000silverbullet
2000silverbullet is offline
There's a bolt or 2 (torx) on the floor at the break in the rear seat (where the 2 seats meet the 1). I think it may have been where the rear sub was, can't remember since I took my sub out a while ago.
It's real floppy at the seat joint when you get it out so make sure you have someone around to help.
Old 03-20-2012, 09:15 PM
Speicher's Avatar
Speicher
Speicher is offline
The rear seat backs are latched to the back wall. Raise the seats up, that gives you more clearance behind the seat, also helps to remove the headrests. Theres a small pin, if I'm not mistaken you pull up on, that releases the latch. One behind each headrest.
Old 03-30-2012, 05:15 PM
ZEALOUS_DRAGON
UGH!!! I dont see the dag blamed thing!
Old 03-30-2012, 06:15 PM
2000silverbullet
I'm sure you already checked but the seat belts aren't holding it up or anything right?
Old 05-14-2012, 11:06 PM
ZEALOUS_DRAGON
No the seatbelts are not affecting it. Its almost like there is a bolt still holding it to the floor at the rear of the center braket. I have tried again and still unsuccessful...
Old 05-15-2012, 05:59 AM
2000silverbullet
I tried looking on the parts diagrams for the rear seat but it's too difficult to see in the pics. Did you remove the storage bins? It makes it easier to work on.
I'd take a pic of mine but my speaker box blocks the middle/right side of the rear seat. I might be able to get one from the left side, will check it out when I leave for work.
Old 06-01-2012, 11:23 PM
ZEALOUS_DRAGON
Ya, I removed the storage bin and also removed 3 bolts and 3 nuts and still cant get it out. I can rebuild a motor from the pan up and yet I cant remove a seat.... lol
Amelio
6.7L Power Stroke Diesel
12-29-2016 07:43 AM
krazy_horse
02-07-2015 09:13 AM
rocdril
2004 - 2008 F150
06-22-2008 06:05 AM
mikeyw
2004 - 2008 F150
06-30-2007 09:35 PM
jhooch
03-31-2007 02:04 PM
Quick Reply: How To Remove The Rear Seat of a 2012 F-350
