fuel gauge wiring diagram - Ford Truck Enthusiasts Forums
Old 03-19-2012, 11:12 PM
Kelly Dvorak Kelly Dvorak is offline
Kelly Dvorak is starting off with a positive reputation.
Question fuel gauge wiring diagram
I have an 87 ford f250 with a 4.9L and cannot find a wiring diagram to install a digital fuel gauge. truck has dual tanks with selector switch. I have two new fuel sending units to install once I figure out what wire to attach to the new gauge. I plan on using a dip switch for the main power instead of using the accessory wire. I have a Chilton manual but there are not any wiring diagrams listed.
Old 03-20-2012, 08:54 AM
Lazy K Lazy K is offline
Lazy K is a name known to allLazy K is a name known to allLazy K is a name known to allLazy K is a name known to allLazy K is a name known to allLazy K is a name known to all
http://www.ford-trucks.com/forums/11...ge-issues.html Have a look at the post by rla in this thread.
Old 03-20-2012, 09:03 PM
thank you
I really appreciate it Lazy k, Month of looking and finally got on here. should have done it sooner. thanks again that is exactly what I was looking for.
Old 03-26-2012, 09:45 PM
need help again
Thanks to lazy k I got the fuel fixed now I need help figuring out why my truck does not move. Today I was driving and went to shift into second gear and something popped and blew a puff of grayish smoke and now it goes into all gears smoothly, but does not move. I have a Chilton manual but it is not helping. I really hope I do not have to change the tranny. What could be all of the problems that I can start with before I dismantle the transmission to install a new clutch. 87 f250 4.9L 4 speed trans. I am totally lost and really ned help before I have to put it into a shop.
Old 03-27-2012, 08:07 AM
If 4x4 check that the transfer case has not jumped into neutral. Also check if it moves when shifted into 4lo.
However it may be that the splined hub has sheared from the clutch plate, would need to pull the trans to check that. Could also be that the pressure plate has failed.
Old 04-19-2012, 01:28 AM
truck looses power while driving
O am losing my mind trying to figure out what is wrong. When I am driving once the truck is warmed and cruising it starts loose power until I hit the gas and it runs nice until I start even out at any speed. This happens only when I get about five miles or so every time. There is what I have done to fix this problem.
I have changed plugs and gapped them properly, new plug wires, new water pump and thermostat, new intake seals exhaust seals, valve cover gasket, EGR gasket, new vacuum lines, new power steering pump, new oil pump, new clutch, new high pressure fuel pump, low pressure front fuel pump. 2 new fuel filters, oil filter, new oil, and fresh gas. I also cleaned each fuel injector and they work fine. I have checked all fuses and relay's and they are good. One thing I have done was when I bought the truck I took of the PCM and found that there was a bad 12.00000 MHz crystal that was corroded and broke. I purchased a new one off of the net and soldered it in. I am not 100% sure that is the right crystal but it made the truck start to run. Is there anything that I could be missing and can change?
Old 07-28-2013, 01:30 PM
Rhonda Payne Rhonda Payne is offline
Rhonda Payne is starting off with a positive reputation.
!985 Ford f150 Truck
My fuel gauge is always saying empty also. Repalced intake fuel pump twice. The 5 Amp fuse keeps blowing for the dash lights every time I replace it too. Any suggestions?
Oil pressure switch wiring to fuel pump cutoff relay Davie J. 1987 - 1996 F150 & Larger F-Series Trucks 2 06-07-2016 12:47 PM
wiring diagram for 75 f250 tbruz 1973 - 1979 F-100 & Larger F-Series Trucks 4 07-08-2015 01:46 PM
Wiring diagram 70f250highboy 1967 - 1972 F-100 & Larger F-Series Trucks 1 05-20-2015 08:58 PM
Fuel Gauge 1973F100Kid 1973 - 1979 F-100 & Larger F-Series Trucks 2 12-15-2011 02:50 PM
1989 F700 370 V2 wiring diagram fuel pumps markmc60 Large Truck 0 08-19-2011 10:03 PM
Tags
2007, 87, car, diagram, digital, f100, f150, f250, ford, fuel, gas, gauge, install, vintage, wiring
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
