weight scales
#31
#32
#33
Truck weighing
Here is a good site regarding how to calculate your weights and how to use CAT scales.
Towing Weight Calculators - How to Weigh Your RV - Answered
#34
Ok, I didn't realize you were hauling that much on the truck in addition to the trailer. You need to get some of the weight iff the truck and on the trailer instead, but you can't since the trailer is already over capacity.
You could put a heavier axle under that trailer, but don't forget you would also need higher capacity tires. Only problem here is that you are still on a frame that's only designed for 3500 lbs.
IMO you should find a larger tandem axle trailer and then sell the one you have now to offset some of the cost. Then you would have a trailer with significantly more capacity, and it probably wouldn't cost much more in the end than it would to "upgrade" your current trailer.
Edit: I don't know how close this is to you, but it looks like exactly what you need at a pretty good price.
16 ft. Utility Trailer W/ Ramps
[IMG]http://images.craigslist.org/5L35Ge5Mf3G53Ia3Fbc3676da3b0e90641877.jpg[IMG]
#35
This is both my first Ford and my first diesel and I was impressed.
System
1999 to 2016 Super Duty
01-20-2012 11:05 AM
jeffdoerr
27
11-22-2009 06:09 PM
