Jeff's 73 F100 Build Page - Page 3 - Ford Truck Enthusiasts Forums
  #31
Old 03-20-2012, 04:25 PM
jfish045's Avatar
jfish045 jfish045 is offline
jfish045 is starting off with a positive reputation.
A little purple power on the fan shroud, had plenty of water thanks to mother nature!! lol! About 20 minutes, some radiator fluid and warm her up... I was tooling around town in nothin flat. Even in the rain, got my fix for the day.
  #32
Old 03-20-2012, 04:27 PM
jfish045's Avatar
And now I'm off to LMC to pick up bed bolts, only live about 20 minutes from the Headquarters.... Gonna pull the bed tomorrow rain or shine!!!
  #33
Old 03-20-2012, 04:28 PM
Rogue_Wulff's Avatar
Rogue_Wulff Rogue_Wulff is offline
Rogue_Wulff is a splendid one to beholdRogue_Wulff is a splendid one to beholdRogue_Wulff is a splendid one to beholdRogue_Wulff is a splendid one to beholdRogue_Wulff is a splendid one to beholdRogue_Wulff is a splendid one to beholdRogue_Wulff is a splendid one to behold
Congrats!
I had forgot how much smaller the standard radiator is, compared to the super cooling factory A/C unit. Huge difference......
  #34
Old 03-20-2012, 05:52 PM
jfish045's Avatar
Yea, this is a replacement aluminum radiator. About 15 lbs lighter than the old one I took out and should do a much better job cooling too.
  #35
Old 03-21-2012, 01:27 PM
jfish045's Avatar
Well progress today so far, caved in due to the rain and paid $20.00 to have my local mechanic remove the bed bolts. So at this point the bed is ready to come off when my axle flip kit gets here. I"m hoping early next week Had a buddy come over yesterday evening and we set out to find my miss. We put some sea-foam in the motor to get a clean start, lol then proceeded to smoke out the neighbors!! Think we narrowed it down to the number 4 cylinder that had a spark plug wire arcing to the exhaust manifold. I was reminded why I hated pulling plug wires while the truck is running!!! Lit me up!! So, my plan for today is to run out and get new plugs, wires, cap, points like I should have from the start. I have a new MSD coil and 6AL box sitting in my tool box but want to save that for after the rebuild this fall.
  #36
Old 03-21-2012, 10:16 PM
jfish045's Avatar
Ok, got a little miss that I'm trying to trace down but figured I better take care of the basics first. Went to the parts store and picked up a carb rebuild kit, plugs, wires, cap, rotor, and condenser. Still raining here in Kansas so I figured I would rebuild the carb tonight and change the rest tomorrow. Here's the pics.
  #37
Old 03-21-2012, 10:21 PM
jfish045's Avatar
She was DIRTY!!! Spent quite a bit of time cleaning with a small paintbrush and toothbrush... Wow went through the card cleaner too, 2 entire cans!!! Got it back together and she fired up just fine, set the choke and idle but still have the miss... Looking to replace the rest tomorrow to see where it gets me.
  #38
Old 03-21-2012, 10:41 PM
jfish045's Avatar
Had to laugh!!!! Was digging through my tool box and ran into this, another FORD Bronco lover!!!! LMAO!!!
  #39
Old 03-21-2012, 11:52 PM
militarymonark's Avatar
militarymonark militarymonark is offline
militarymonark is starting off with a positive reputation.
LMAO!! that's funny
  #40
Old 03-22-2012, 11:24 AM
jfish045's Avatar
Ok all, after a cup of coffee I'm getting ready to go out and finish the tune up. The UPS guy stopped by this morning and delivered my flip kit from airbagit ! First things first though, plugs, wires, cap, points, and condenser. Then we keep our fingers crossed and hope the miss goes away. Will have some photos shortly.
  #41
Old 03-22-2012, 02:38 PM
jfish045's Avatar
Well, got the tune-up all finished and low and behold I think it solved my miss!!! So I was walking around admiring my fine work, looked down and the fuel pump sprung a king size leak!! She's gonna fight me to the bitter end!! I WILL NOT give up.... Off to the parts store for a new fuel pump I guess, hopefully before the rain sets in again..
  #42
Old 03-22-2012, 04:30 PM
Might be a bit too late, but here goes. The 360/390 fuel pumps from slightly older trucks have a large canister type fuel filter on the bottom, and are an easy "upgrade" for the 73-76 models that relied on just the small filter at the carb. Cost difference between the 2 styles is minimal, and the filter can be replaced. This added filter can save a lot of grief caused by the small filter doing it's job and getting clogged easily. It doesn't take much crud to really clog up that small filter quickly.
  #43
Old 03-22-2012, 04:49 PM
jfish045's Avatar
Rogue, actually thought about that but opted for the cheap one right now. This fall when I rebuild the motor I'll be installing a Holley 110 blue pump to supply the fuel. I am however pulling the little filter off the carb and replacing it with a better in-line canister style.
  #44
Old 03-23-2012, 12:30 AM
jfish045's Avatar
Painted the flip kit just to keep it from rusting, gonna try and get it installed in the morning.
  #45
Old 03-23-2012, 01:51 PM
jsutton's Avatar
jsutton jsutton is offline
jsutton is gaining momentum as a positive member of FTE.
Subscribed!
What's the plan on lowering the front? Sorry if I missed where you mentioned that already.
56 F100 D CB28424 1948 - 1956 F1, F100 & Larger F-Series Trucks 62 01-27-2015 01:52 PM
94 Explorer with wierd problem Redneckfordf2502002 Explorer, Sport Trac, Mountaineer & Aviator 10 06-13-2014 10:20 AM
This is Crazy Cooter!(lots of pictures) MikePacey 1973 - 1979 F-100 & Larger F-Series Trucks 8 08-06-2013 10:24 PM
Just drove her home jfish045 1973 - 1979 F-100 & Larger F-Series Trucks 10 03-19-2012 03:08 PM
My 65 Build Lrgfather 1961 - 1966 F-100 & Larger F-Series Trucks 22 10-31-2011 11:40 AM
Tags
73, f100, filter, fuel, location, mirrors, original
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
