Jeff's 73 F100 Build Page - Page 2 - Ford Truck Enthusiasts Forums
Old 03-19-2012, 01:40 PM
jfish045's Avatar
jfish045 jfish045 is offline
jfish045 is starting off with a positive reputation.
True!!! Not wanting to take the intake off right now, hoping I can nurse it till winter and I'll rebuild the motor. Yea you're sending all the rain up from OK...Lol Kids are on spring break and I took a few days off so my sons and I could work on the truck... So now I'm glued to the laptop I guess.
Old 03-19-2012, 02:28 PM
bucks77ford's Avatar
bucks77ford bucks77ford is offline
bucks77ford has a very good reputation on FTE.bucks77ford has a very good reputation on FTE.bucks77ford has a very good reputation on FTE.bucks77ford has a very good reputation on FTE.
Looks like a very solid and nice truck there. Thanks for starting the thread and keep us posted on any progress you make. Also, make sure you take some straight on good pics of those decals (if you haven't already). That way if you ever get to a point of repainting the truck and want to add those decals, you have a nice pic to get them reproduced. You can't just buy them anymore.
Old 03-19-2012, 02:44 PM
jfish045's Avatar
Great advise bucks, thanks. I'll take some good side photos s soon as the sun comes back out. Noticed I couldn't find those in decal or mask in the LMC catalog.
Old 03-19-2012, 02:47 PM
mikeo0o0o0's Avatar
mikeo0o0o0 mikeo0o0o0 is offline
mikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud of
Quote:
Originally Posted by jfish045 View Post
Mike, do you have a build page? Would love to see some pics of your progress as well.
Yeah, there's a link to it posted in post # 5 of your other page (Just drove her home).
I'm trying to get mine ready for paint, then after that (hopefully) it'll be down hill.
Old 03-19-2012, 02:56 PM
jfish045's Avatar
Mike I saw your link, great page man! If you need any photos for reference let me know. That is if your going with those rocker stripes
mikeo0o0o0's Avatar
Popped the valve cover off on the bank that it seems to be coming from and noticed one rocker doesn't seem to be getting oil through the pushrod.
Just a note, FE rocker arms don't get their oil through the pushrods like other Ford engines. These are old technology, they get their oil through the rocker arm shaft, from passages drilled into the oil gallies.
Here's a drawing of the lube system for the 360/390.
Old 03-19-2012, 03:05 PM
mikeo0o0o0's Avatar
Thanks, I've got a NOS stripe kit but I'm not going to use it. I'm having the stripes painted on, they are going on under the clearcoat.
There are two reasons I'm doing that. First the kit I bought got damaged so I don't have a complete kit anymore and second the stripes are no good anyway. These kits only have a shelf life of about two years. After that the adhesive deteriorates and is no good anymore and the masking paper won't peel off.
I bought the kit like that knowing it wasn't any good. I just wanted to use it as a template for when the stripes get painted on.
Another plus to painting is the stripes will never crack, fade, or peel like the stock vinyl stripes will do.
Old 03-19-2012, 03:25 PM
jfish045's Avatar
Mike I just spent the last half hour going through your build page, man that's just awesome.. I'll be using it as a reference I'm sure... I agree with painting the stripes, leaves a smooth finish that stays colorfast. I'll do the same if I repaint, base/clear maybe House of color mandarin Orange/ whit stripes. I just gotta leave the orange though, loud as heck and everyone just loves it. Was your 390 a factory 4V? did you do anything with the compression when you rebuilt it? I'm hearing 360 pistons will bump the compression a touch over stock. Hope you don't mind the all the questions. I'll rebuild my motor over the winter this year if it can make it through summer. Oh, thanks for the diagram... So the lifters and pushrods get no oil other than drain back?
Old 03-19-2012, 04:19 PM
mikeo0o0o0's Avatar
Lifters and pushrods get plenty of oil, in fact too much oil. It's easy to pump a lot of oil into the valve area. A common (and cheap) mod to the lube system is to install a Holley carb jet in the oil feed galley. This will restrict oil flow to the head and keep it down where it belongs.
Mine was originally a 360 2bbl. When I rebuilt it I bumped it up to 390 specs. 360 pistons are pretty much the same as 390 pistons. I've torn down stock, untouched engines and found both 360 and 390 4 bbl pistons in it.
Another thing to check just to be sure. If that's the original engine in your truck, confirm that it is a 390 and not a 360. The fourth character of the VIN will be "H" if it's a 390 and "Y" if it was originally a 360.
Old 03-19-2012, 04:36 PM
jfish045's Avatar
Yea Mike, it's the original "H" motor I checked it the other day to be sure. I've been hearing that the 390 2V was 9:1 compression???? Not sure if that's correct though. Heard by putting the 360 pistons in it raises that compression closer to 9:5 or better. Now this is considering the stock heads I'm using 74cc??? I'm researching cams right now for the future rebuild. The Lunati Voodoo is looking pretty good to me right now.
Old 03-19-2012, 04:54 PM
Wichita Sam Wichita Sam is offline
Wichita Sam is starting off with a positive reputation.
Very nice truck, Do Grandpa proust.
Old 03-20-2012, 12:25 AM
Rogue_Wulff's Avatar
Rogue_Wulff Rogue_Wulff is offline
Rogue_Wulff is a splendid one to beholdRogue_Wulff is a splendid one to beholdRogue_Wulff is a splendid one to beholdRogue_Wulff is a splendid one to beholdRogue_Wulff is a splendid one to beholdRogue_Wulff is a splendid one to beholdRogue_Wulff is a splendid one to behold
The 390 2V back in the 60's had ~9.5:1 CR. The truck 390 from 68 to 76 was around 7.8-8:1.
The older 390 2V pistons became 360 pistons, and 410 pistons found their way into 390 truck engines.
Bumping the CR into the low-mid 9's and a mild-ish cam, can really wake up one of these old truck 390's. Lunati has a pretty good reputation for FE cams.
  #28
Old 03-20-2012, 10:04 AM
jfish045's Avatar
Thanks for the info Rogue, so when I go to rebuild this motor I can use a 360 piston to bring the compression up? Not looking to overbuild just want a nice healthy motor that sounds good but dependable (as possible) lol Been hammering the fe thread to see what everyone is putting together.
  #29
Old 03-20-2012, 01:40 PM
360 pistons are a common swap into a 390, as they will bump the CR back into the 9's, and cost no more than any other "stock" piston.
Combined with a mild-ish cam, (like the comp 268- very similar to the factory 390GT/428CJ cam) and recurving the dist (if needed) to match, gives a decent return on power/torque without sending the MPG any further into the toilet. Under the right driving conditions, it can actually give a mild boost to the MPG, as the engine doesn't have to be worked as hard to make the same power as stock.
If you're already looking in the FE section, you should be able to find many threads that talk about this very subject.
  #30
Old 03-20-2012, 04:21 PM
jfish045's Avatar
Still raining like crazy today but the radiator shop called and said my new one was in, heck with it I went and got it!! Plans for today get that baby back in and get the old girl up running again.
56 F100 D CB28424 1948 - 1956 F1, F100 & Larger F-Series Trucks 62 01-27-2015 01:52 PM
94 Explorer with wierd problem Redneckfordf2502002 Explorer, Sport Trac, Mountaineer & Aviator 10 06-13-2014 10:20 AM
This is Crazy Cooter!(lots of pictures) MikePacey 1973 - 1979 F-100 & Larger F-Series Trucks 8 08-06-2013 10:24 PM
Just drove her home jfish045 1973 - 1979 F-100 & Larger F-Series Trucks 10 03-19-2012 03:08 PM
My 65 Build Lrgfather 1961 - 1966 F-100 & Larger F-Series Trucks 22 10-31-2011 11:40 AM
Tags
73, f100, filter, fuel, location, mirrors, original
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
