Help for my 97 PSD. It has an intermittent miss (cut-out) at no or little load throttle. Seems to be getting worse and bucks sometimes with cruse control set. New Ford CPS installed and almost new Dorman TPS. No other symptoms noticed and seems to run fine otherwise. Any help or suggestions would be greatly appreciated!!!!!!!! Thanks all!
Stock 7.3, 230,000 mi. 4X4, E4OD, with 3" Diamond eye down pipe and straight 4" exhaust. Filters and oil changed recently and after problem started.
Thanks again!
Have you tried a new ford or IH cps? Cheap easy try, and they are known to do some weird crap, along with you need to carry a spare, they are that common to fail.
Brand new Ford CPS, no change. I will check TPS voltage. Thank for all the help guys! I bought my truck with 160,000 miles on it and I love it!!!!!!! I, looking to "chip" it soon and install an intercooler. Thanks again!!!!
I understand that it takes a higher end scan tool to read the PSD's, is this true? I've been looking at them but there are so many to choose from? I'm open to suggestions?
Yes you'll need a good scanner.
I use the areoforce scangauge it around 250
If you have a laptop you can get a AE for around 250
Both of these can be picked up from clay at riffraff
