rack and pinion
Old 03-18-2012, 10:16 PM
scoobyvanjack's Avatar
scoobyvanjack
scoobyvanjack is offline
rack and pinion
hi
any one out their find a way to add rack and pinion steering in an econoline?
svj
Old 09-02-2013, 09:52 PM
OGB's Avatar
OGB
OGB is offline
You got to be kidding as much as it is to rebuild a stock box,no one has put in a rack and pinion in a first gen econoline. I was hoping for some pics so I didn't have to reinvent the wheel oh whell I helped put one in a 55 ford pu years ago should be about the same . . . maybe
Old 09-03-2013, 03:26 PM
Beechkid's Avatar
Beechkid
Beechkid is offline
Well, if you are doing it just to say I have it ok...if its for ease of steering, turning radius, performance...Hmmm, no.....it will actually increase the turning radius and does nothing in the performance arena.
Old 09-04-2013, 08:17 AM
OGB's Avatar
OGB
OGB is offline
So I have your permission? . . . I was looking at cost and keeping my hands busy. Sense my box is selfdestrucking I'll guaranty the steering will be easier. It may or may not turn sharper depending on what rack I use. Plus the option of power steering if I want (I don't). Other sites have recommended a Toyota previa or VW Vanagan because of the location of the steering column in relation to the axle, the Toyota uses a 90 degree box to change the direction of the steering column. Apparently the column is in front of the axle and the rack is behind the axle like ours not sure of the the VW setup. At the local pull a part part would be about $120 (steering column, rack and 90 degree box)
Old 09-04-2013, 05:31 PM
Beechkid's Avatar
Beechkid
Beechkid is offline
Look, I did not mean to imply you need a "permission" to accomplish this but, I was assuming you wanted something that would not only be doable 9which it is) but be effective as well.....if I may suggest, you can get the oem steering box rebuild kit (including fast steering which would reduce the number of turns by about 20%) by these guys at less than what you are looking to spend on used parts....
Classic Mustang Disc Brake Conversions and Power Steering
While they are not experts per say on the Econo's, I would bet they would have some very good advise on part selection and may even have something that would work with a higher degree of success, etc.
Old 09-06-2013, 05:59 PM
EmilBarnabas's Avatar
EmilBarnabas
EmilBarnabas is offline
Some have tried a Mustang II font axle. I read somewhere that a VW van axle fit real nice. Search for it.
Old 09-23-2013, 06:39 PM
Roger Carter's Avatar
Roger Carter
Roger Carter is offline
Before you get too far along on your r&p conversion, I suggest you look up the term "bump steer".
Roger Carter
Old 09-23-2013, 06:59 PM
OGB's Avatar
OGB
OGB is offline
If the rack was mounted to the front axle it would eliminate the bump steer problem. The shaft from the 90 degree box to the rack would have to be a sliding shaft with universal at both ends. The location of the rack would be approximately where the tie rod is now. Still in thinking stage (no cash) but that's what I invision. If I get the parts from local pull a part and fab brackets I should be able to put it together for half of what they want to rebuild a stock box.
JNye
01-24-2019 04:03 AM
salf100
01-02-2011 01:11 AM
mfire138
08-12-2008 07:08 PM
handx2
05-27-2004 07:16 AM
Quick Reply: rack and pinion
