Compilation of YOUR work
Basically, im interested in what you guys have done to your IDI since you purchased it. Im sure many of you have done more than you would like to recall, and to compare to my list would be laughable, but just for *****s and giggles lets see it.
So I bought this truck on I think the 14th of January, 2012. And pretty much have been at it trying to care for it and give it what it needs since. So I begin.
Ill try to list in order of when i purchased said items.
Truck = $3,500.00
Two 4' Black CB Whips = $42.00
Running Boards = $20.00 (Lots of fabricating)
Starter Solenoid = $13.00 ($5.00 of which was S+H)
Neutral Safety Switch = $39.99 (Total Rip-Off imho but meh)
8 Reman Injectors = $119.00
8 Glow Plugs = $91.00
New Wipers = $29.99
New Passenger Side Speaker = $10.00
New Return Line Kit = $40.00 (Needs to be redone due to my failness)
New to me Head Unit = $20.00
New TPS = $39.99 (Have not installed yet)
New Intake System:
Dual Plenum = $60.00
Four 5" Humps = $15.00
Miscellaneous Hardware = $10.00
Big K&N Filter = $52.00
Smaller Spectre Filter = $18.00
New Pyrometer = $88.00
New Belts = $45.00 (I think it might have been more cant remember, this one was messy cause we got all the wrong belts the first time then we had to go two 3 different stores to get the right ones Ill track it down.
New Oil = $60.00 (It was on-sale, and by far one of the messiest jobs ive ever done, but it was about 4 quarts low....SMH at the PO and me not getting to it soon enough)
Pulse Sensor = $6.00
# 1 Injector Line = $48.00 (Rip Off)
# 1 Injector Line = $20.00 (Scrapped it cause i broked the other one)
#'s 1,2,3,4,5,6,7,8 Injector Lines $25.00 (HEHE Got Lucky and found a spare set for CHEAP!)
And thats just things that could actually go on the truck - Total 4,411.97
Here are some tools I have purchased for this thing in order to work on it.
New 168 Piece Craftsman Socket set = 139.00 (I used mostly metric stuff for my Mitsubishi Eclipse and I personally didn't do a lot of that wrenching. But a good standard set is a must for this.)
Tap and Drillbit for Pyro = $15.00
4 and 1/4" Belt Wrench for the Oil Filter = $8.99
Bunch of 1/4" 3/8" and 1/2" Extensions = 24.00
Fold out Step up Ladder = $20.00 (By far one of the better investments ive made )
Wire Crimper = $17.00
Box Cutter = $10.00 (Clearly didnt use it to cut boxes )
Lubes,Anti-Seize,Coolant, Other Misc things = $50.00 (Just for good measure im sure im leaving out things)
Total = $283.99
Add those two totals together you get $4695.96.
Out of these things, do you guys notice anything major Im missing? Its a 91 F350 4wd 7.3 L CC with an E40D with about 152,xxx on it.'
By the way - Just wanted to let everyone know, i turned the fuel pump up about 1/2 a turn (Whoops) She was sure rolling coal..but she was drowning nonetheless so i turned it back down a quarter of a turn, and damn if she isnt pulling like a champ couldnt be more happy and i dont think she could be either.
Truck = $3,500.00
New Wipers = $29.99
New Intake System:
Total = $283.99
Just bought mine last month. I don't have prices for it all, but so far:
- New glow plugs
- New door lock cylinders
- Fuel line return kit
- New belts
- New hoses
- Coolant flush (to baseline coolant for SCAs)
- Brake flush
- New fuel filter (NAPA unit with water separator built in)
- New transmission fluid
- New wipers
- New head unit
- New speakers
- New wiper ****
- New tires
- New thermocouple for Banks EGT gauge installed
- New air filter for Banks setup (million miles my ***!!!)
- New CDR calve
- Shell removed
- Running boards removed
- Washed (better not get used to it. It won't happen often)
- All zerk fittings greased
- Changed diff fluid (complete with 08+ diff cover)
Left on the 'to do' list"
- Oil change
- Change shocks (KYB Monomax)
- Line-X
- Tint
- Take care of a few minor rust spots
- New floor mats
- Dashmat (a must in sunny SoCal)
- Boost gauge (Banks 0-15 PSI unit)
- Crank up the IP (maybe)
Jobs I hope can hold off a bit more:
- Clutch!
I'd rather not think of the total on everything right now. I've been having too much fun having a pick-up again and working on it. It's immensely satisfying. Oh, and a big thanks to all those whom have helped me on here! Couldn't do half of it without the knowledge freely shared on this forum.
Mike
- New glow plugs
- New belts
- New hoses
- Brake flush
- New wipers
- New head unit
- New speakers
- New wiper ****
- New tires
- New CDR calve
- Shell removed
- Oil change
- Line-X
- Tint
- New floor mats
- Clutch!
Mike
Well way to much to list really but I bought my hobby/toy when I turned 15 and been working on it for a decade. The big recent stuff is in the sig last time I figured it up I have around 1600 in it. That's wheels tires stereo engine/trans swap and turbo included with the differnt trucks it took to build the beast.
on
https://www.ford-trucks.com/forums/m...ure86636-1.jpg
https://www.ford-trucks.com/forums/m...ure86637-2.jpg
https://www.ford-trucks.com/forums/m...ure86638-3.jpg
https://www.ford-trucks.com/forums/m...ure86639-4.jpg
https://www.ford-trucks.com/forums/m...ure92688-5.jpg
and recent:
@ 84,000 - ........ (February 2012) miles
Two Used OEM Front Fenders Installed.
New 94-97 PSD Front Bumper w/ Dual Super Duty Lights.One clear & One Yellow set.
Wire Loom Installed Over OD Cancel Switch Wires In Steering Column (preventive maintenance.)
Fixed Broken Dash Mount.
Replaced Wiper Arm Pivot Mount (i burned it up cutting out my hole with the torch for cowl induction back along lol! oops.)
Replaced Cruise Control Servo w/used '95 OEM.
Adjusted Front Tanks Sending Unit So Gauge Reads Empty A Bit Sooner.
HVAC Bulb Replaced.
Water In Fuel Light Circuit Test.Passed.
Removed A Couple Worthless Pounds Of Unused Factory Exhaust Brackets/Hangers etc.
Adjusted Hydroboost Pushrod For Brake Pedal.180 Degrees Rotation.
Fast Idle Solenoid Plunger Adjusted.
New Narrower Rear View Mirror Installed To Fit Backup Cam LCD Better.
Repaired Fuel Selector Dash Switch Mount.
Two New Autocraft Gold Batteries.
New BRG/BLK Tu-Tone Paint Job (March 16 2012)
almost done..............i hope.
and recent:
HVAC Bulb Replaced.
Haven't done much other than drive the wheels off it. Have owned it 10 years.
Replaced injection pump.
Replaced serp belt, tensioner, idlers and a new vacuum pump
Mounted back up lights under bumper
Rear brakes and replaced a leaking rear hub seal
Replaced tires
New CD player with Ipod input
Installed a 105 gallon fuel tank
Replaced glowplugs with BERU's and replaced thermostat
Replaced batteries
Replaced water pump and heater hoses
Installed Shelv It and mounted CB and scanner overhead
Replaced front spring bushings, shackle bushings and track bar with poly
Installed 40/20/40 seat from 97 HD
Perform clutch switch mod
Replace fuel pump
Installed second set of 35 BFG's
Rebuilt front driveline, CV, u joints
Replace injectors and fuel return lines
Install billet grille, clear headlights and markers
Replace batteries again and built all battery cables
Replace ball joints, front brakes, wheel bearings, front axle u joints, diff bearings, complete steering linkage, carrier bearing
Will be doing a SMF clutch, replacing all hydraulics, and rebuilding the pedal assy. Replacing windshield
Jason
Replaced tires
Replaced batteries
Replace fuel pump
Jason
and recent:
HVAC Bulb Replaced.
and recent:
HVAC Bulb Replaced.
oh lord...lets see here...
Dana 60 front axle swap/rebuild
new tierods
new steering box
new rad and coolent
new GP's
new tires
added coolent filter
Banks sidewinder
new exhaust
cb radio
3G Alternator upgrade
new batteries
plus all the regular maintinance stuff
planning a clutch later on this spring/early summer when things slow up a bit
also plannning SD front springs when i do the clutch
new tierods
new steering box
new rad and coolent
new GP's
new tires
Banks sidewinder
new exhaust
cb radio
new batteries
on the 91:
8" lift
front axle
rear axle
crossover steering
rims
tires
mud flaps
bed rails
tool box
f350 badges lol
front bench seat
rear bench seat
sound system
cb
pillar guages
glow plug switch
starter switch
zf5 swap
single mass flywheel
ats turbo kit
4" intake
5" exhaust
radiator
coolant filter
injectors / injection pump
headlight wiring upgrade
gawd thats alot of $$$ if i add it up
8" lift
front axle
rear axle
crossover steering
rims
tires
mud flaps
bed rails
tool box
f350 badges lol
front bench seat
rear bench seat
sound system
cb
pillar guages
glow plug switch
starter switch
zf5 swap
ats turbo kit
4" intake
5" exhaust
radiator
coolant filter
New Radiator / Flush
Batteries & Cables
Return Lines
CDR Valve
Headlight Relays
Cowl Induction
Tach Sensor
Vacuum Pump
PS Pump
Remove Running Boards
87+ Door Panels
Newer Dash Pad
Bench with Armrest
Windshield (non-leaking)
Window Weather-stripping
Speakers
Head Unit
Satellite Radio
CB
Tires
Brake Booster
Brake Fluid Flush
Swapped Rear Axle w/:
3.55LS
Rebuilt Drums
Rear Sway Bar
Fixed Fuel Pick-ups in both tanks
Needed:
A/C convert to R-134a
Solid Rear Window
Tint
Batteries & Cables
Return Lines
CDR Valve
Headlight Relays
Cowl Induction
Tach Sensor
Vacuum Pump
PS Pump
87+ Door Panels
Newer Dash Pad
Bench with Armrest
Speakers
Head Unit
Satellite Radio
CB
Tires
Brake Booster
Brake Fluid Flush
3.55LS
Rebuilt Drums
Rear Sway Bar
Needed:
Solid Rear Window
Tint
ill play
appox 4 weeks ago i purchased an 85' F250 4x4 $900
TTB 50 was literaly falling off, 4" or 6" lift w/35's it had to go!
D60 swap $900
6 stock steel rims, brand new tires for front, 75% tread tires on rear $50 + my bald 35's on 16.5" rims (thank you CL)
injector return line kit >$100 dont remember exactly how much
GP's w/manual momentary switch in cab >$90
Starting it with OUT ether! $PRICELESS (haha, had to toss that in there)
voltage reg $15
made my own 2/0 battery cables $150
relay to wire up exsisting E fans correctly >$10
upper and lower rad hoses + coolant ~$80
better condition/used seat $free from friend
2 front brake lines $14
some other parts i got for free
power steering pump/steering box
2 33"x12.50x16.5 tires
4 16.5" alum rims
both fuel tanks w/senders
things to do still
replace bed/tailgate
replace both doors and all weather striping
replace viynal flooring
re upolster seat
fix guages
replace fuel tanks
find/install front bumper
take blocks out of the rear to finish lowering it back to stock
paint
fix dip stick tube (sheared off)
thats just what comes to mind...
I bought this truck with intentions of cleaning it up and making it into a nice DD.
and providing a home for the 12V cummins in my garage.
plan is to do a cummins,nv4500,np250 swap
D60 swap $900
voltage reg $15
4 16.5" alum rims
things to do still
re upolster seat
fix guages
replace fuel tanks
paint
purchase price1700(I think)2009
new tran-3000
oil cooler o rings and gaskets- 60
new IP- 400
glo plugs-80
injectors-130
tires-600
new bed-75
paint- 150
oil changes 70 ea every 3000 mi
front seats 40
elec fuel pump and all new lines- 200
tracking down weird short in steering column-900
tracking down pinhole leak in fuel line-400
starter 3x- lifetime warranty good thing-275
all new sensors for tranny and ip
misc- 1500
did everything myself except the tracking parts and putting in new tran total about 10k and I'm not done yet!!!
new tran-3000
new IP- 400
glo plugs-80
injectors-130
tires-600
new bed-75
paint- 150
front seats 40
misc- 1500
