Compilation of YOUR work
bought truck in 2010 - $150
glow plugs
injectors
injection pump
radiator
water pump
heater core
batteries
positive battery cable
vac pump
mech. lift pump
calipers
one rear drum
everything with rear brakes
mlps switch
tps
brake master cylinder
front brake hoses
front brake line
VSS
two rear tires
rear leaf spring hangers and shackles
home made cowl intake
glow shift boost, pyro, tranny, and pod
sunpro water temp
sunpro vac gauge
tensioner pulley
idler pulley
serp belt
foam for inside the driver's seat
two oil changes
two fuel filters
two air filters
weld an axle pivot bracket back together
weld the little bracket that bolts the factory dp to the tranny bell housing
deleted RABS vavle
new t-stat
Within the next month i WILL be doing tie rods, radius arm bushings and front sway bar bushings.
glow plugs
injectors
injection pump
radiator
water pump
heater core
batteries
vac pump
mech. lift pump
calipers
one rear drum
mlps switch
tps
front brake hoses
front brake line
VSS
two rear tires
sunpro water temp
sunpro vac gauge
tensioner pulley
idler pulley
serp belt
two oil changes
two fuel filters
two air filters
deleted RABS vavle
new t-stat
got my dads 1989 7.3 in august 2009-
new clutch, pressure plate, throw out bearing-1000
new tires-650
new seats- 75
wrecked that nov 2009, bought 1991 not runing 7.3 dec 2009 started engine swap
1991 truck- 1500
misc belts, hoses, gaskets-200
new radiator-500
2 fuel filters-50
new radio-130
new speakers-60
reman E40d-2500
two calipers- 60
new windshield-130
totals up to $6865
that realy hurts to see since Im just a college kid now and no full time job. Goes to show how much we all love our IDIs
new tires-650
new seats- 75
1991 truck- 1500
new radiator-500
2 fuel filters-50
new radio-130
new speakers-60
reman E40d-2500
two calipers- 60
new windshield-130
totals up to $6865
I have had my 91 for about 1 full year. This is what I can think of off the top of my head.
New IP
New injectors
Timing meter to set timing
#8 injector line
8 new Beru glow plugs
A/C flush and regasket
Coolant system rebuild - new rubber, thermostat
Coolant flush and install new FleetCharge antifreeze
Coolant filter
All new belts
Fuel heater fix
New front calipers, brake pads, fluid, and hoses
alternator
vacuum pump
fuel pump
2x fuel tank pickups
Transmission fluid and filter
Rear diff service
Rear diff vent clean and modification
straight pipe exhaust
starter
valve stem in tire replaced
Air intake mod
hydroboost brake system with aux cooler and filter
New MC with hydroboost install
Filters, fluid, etc maintenance
Things left to do:
Install Banks Sidewinder
4" straight pipe
Pyro and boost gauges
Trans temp gauge
Trans command
HHO catalyst system
4x4
Replace broken core support
Finish installing headlight relay mod
New IP
New injectors
#8 injector line
Coolant filter
All new belts
Fuel heater fix
alternator
vacuum pump
fuel pump
Rear diff service
starter
Air intake mod
Things left to do:
4" straight pipe
Trans temp gauge
Trans command
HHO catalyst system
4x4
3fordasho
07-25-2014 10:04 PM
akamacgyver
07-25-2012 05:49 PM
kpjr
10-12-2010 04:39 PM
deanzawistowski
01-27-2008 07:51 AM
