default trailer message - Ford Truck Enthusiasts Forums
Old 03-18-2012, 07:53 PM
irydhd irydhd is offline
irydhd is starting off with a positive reputation.
When I plug in the trailer wiring to the truck. Big seven point one. I get default trailer on the screen. That would mean something wrong with trailer wiring. Well I plugged in trailer and all lights work as they are supposed to. Maybe brakes arent working right?
Old 03-18-2012, 08:13 PM
Dim Sum's Avatar
Dim Sum Dim Sum is offline
Dim Sum has a brilliant futureDim Sum has a brilliant futureDim Sum has a brilliant futureDim Sum has a brilliant futureDim Sum has a brilliant futureDim Sum has a brilliant futureDim Sum has a brilliant futureDim Sum has a brilliant futureDim Sum has a brilliant futureDim Sum has a brilliant futureDim Sum has a brilliant future
If you are getting a fault code when you plug in your seven pin connector, you have a problem.
Now, all of your lights work. Can you plug in your trailer without hitching to the truck? Do the lights work then? If not, then you have a grounding problem. If they do work, then I'd move to your brakes.
Check all of your brake wiring. Make sure each connection at the wheels are solid. Lots of time the scotch block connectors come loose and this is your problem.
Also check your plug. Make sure all of the wires haven't come loose.
Lastly...if all of your wiring is perfect and grounded, you could have an electromagnet bad, but that would be the last thing I'd consider. Most likely, a loose connection for your brakes.
Old 03-18-2012, 08:35 PM
juneau76's Avatar
juneau76 juneau76 is offline
juneau76 has much to be proud ofjuneau76 has much to be proud ofjuneau76 has much to be proud ofjuneau76 has much to be proud ofjuneau76 has much to be proud ofjuneau76 has much to be proud ofjuneau76 has much to be proud ofjuneau76 has much to be proud ofjuneau76 has much to be proud of
^^What he said.
Old 03-18-2012, 08:55 PM
j.grif's Avatar
j.grif j.grif is offline
j.grif has a very good reputation on FTE.j.grif has a very good reputation on FTE.j.grif has a very good reputation on FTE.j.grif has a very good reputation on FTE.
I think that you have to give your trailer a name in the imformation center, default doesent mean theres a problem, it means that the controller has no starting place for trailer brake gain etc. just a guess, but I think thats how it is supposed to work.
Old 03-18-2012, 10:08 PM
flixden flixden is offline
flixden has a good reputation on FTE.flixden has a good reputation on FTE.flixden has a good reputation on FTE.
Quote:
I would give that a shot first.
I don't think "default trailer" means there is a problem. Give it a name!
Old 03-19-2012, 06:01 AM
King Ranch's Avatar
King Ranch King Ranch is offline
King Ranch is gaining momentum as a positive member of FTE.
Yes you just need to name the trailer, when mine had a wiring issue it said "wiring issue" on the screen
Old 03-19-2012, 08:41 AM
trailer default
Yes when I plug in the seven pin without hooking to the truck all lights work. Where would you name the trailer ? Seems like brakes work good.
Old 03-19-2012, 09:43 AM
King Ranch's Avatar
Under info on display
Old 03-19-2012, 03:05 PM
default
Thanks guys for the info on the trailer default. Just name on info screen and it went away.
Pro trailer assist baronmic1 2015+ F150 3 01-09-2017 01:31 PM
Default..... Vinford Other; Brakes, Electrical, Hitches, Weight Distribution & CDL Discussion 5 01-11-2014 01:50 AM
trailer wiring Dave145 1973 - 1979 F-100 & Larger F-Series Trucks 4 08-17-2013 01:35 AM
Trailer Brake Controller (TBC) says "Trailer Disconnected" ...HELP! GTXgp 1999 to 2016 Super Duty 14 05-28-2009 09:54 PM
7/4 Pin Trailer Wiring Harness Replacement mierwins 1999 to 2016 Super Duty 14 02-06-2009 10:13 PM
Tags
2011, 2012, defalt, default, f150, f250, f350, ford, message, trailer, wiring
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
