2500-2700rpm hesitation 5.8
Ive noticed with my truck under hard acceleration there seems to be a hesitation if you want to call it that. Accelerates good till it hits 2500rpm then power seems to drop and come back around 2700rpm. Not really noticeable in 1st or 2nd but its definatly there in 3rd/4th.
No codes (yes I checked lol)
Is this just something normal for a stock 351?
95 f150 4x4 451 e4od
on
That's not normal IMO, I'd suspect plug wire cross firing so maybe try re-routing them to see if it makes any difference.. paying particular attention to #5 and #6 which follow each other in the firing order, and also that the wires aren't contacting metal engine components. Hard to do? Yes.. some plastic wire loom helps protect and space the wires where they overlap and touch the engine.
Well It wasn't do bad, they're all separated now, hard part was getting the 9mm ford racing wires into the holders lol
Still the same thing. It's almost like I let off the throttle for that short time and then hit it again. The exhaust gets quieter during this hesitation as well then picks right back up again
"it will up shift around 4000 with the pedal to the floor" .........It doesn't have much choice but to shift up at this point. It could be that you are at the limit of your machine. It doesnt sound like you are losing power, just not getting it as fast in a higher gear as in a lower gear. That doesn't seem unreasonable for an older truck. Add a pint of seafoam and see what happens.
I'd try the seafoam, then start thinking about the pcm if that doesn't work. Reading off of the back of the Seafoam can in my hand "when added to fuel line, vacuum or induction cleaning systems.......cures hesitation and ping" It doesnt sound like an engine issue if there is 0 hesitation in low gear at the same rpm. The engine does what the pcm tells it to do if it can. Who knows what all the ethanol and crap in the gas are slowly doing to our older vehicles.
