Windshield washer nozzle - Ford Truck Enthusiasts Forums
Old 03-18-2012, 05:51 PM
swheeler swheeler is offline
swheeler is gaining momentum as a positive member of FTE.swheeler is gaining momentum as a positive member of FTE.
Has anyone ever had a windshield washer nozzle stop working? Is there an easy way to unclog it or does it need to be replaced?
Old 03-18-2012, 08:45 PM
Curt's05's Avatar
Curt's05 Curt's05 is online now
Wiser by FTE
Curt's05 has much to be proud ofCurt's05 has much to be proud ofCurt's05 has much to be proud ofCurt's05 has much to be proud ofCurt's05 has much to be proud ofCurt's05 has much to be proud ofCurt's05 has much to be proud ofCurt's05 has much to be proud ofCurt's05 has much to be proud ofCurt's05 has much to be proud of
Try a pin @ the nozzle, if that doesn't work you can remove the plastic grill &
and check out the hoses feeding the nozzles.
Old 03-19-2012, 06:38 AM
Jmatthews's Avatar
Jmatthews Jmatthews is offline
is a BAAAD MAN
Jmatthews has a superb reputationJmatthews has a superb reputationJmatthews has a superb reputationJmatthews has a superb reputationJmatthews has a superb reputationJmatthews has a superb reputationJmatthews has a superb reputationJmatthews has a superb reputationJmatthews has a superb reputationJmatthews has a superb reputationJmatthews has a superb reputation
Unhook the line leading to it and put the air compressor to it. I put some kind of soap in mine once cause I was desperate and after that they all worked much better too.
Old 03-19-2012, 11:35 AM
Tylus's Avatar
Tylus Tylus is online now
Submarines Once....
Tylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputationTylus has a superb reputation
Remove the plastic valence on the top of the firewall. Just a few screws and plastic clips
Then the nozzle will simply pop out. I back flushed mine using a garden hose sprayer
Try the needle first of course. But if it's grit, you'll have to do the surgery. Took maybe 10 minutes luckily
69 Ranchero windshiel waser nozzles Badmrscary Ranchero & 1961 - 1967 Econoline 3 05-22-2016 05:04 PM
How to remove WW nozzle? BPofMD 1999 to 2016 Super Duty 6 09-12-2015 09:57 AM
Washer Nozzle Adlustment Super Mech 1987 - 1996 F150 & Larger F-Series Trucks 3 01-16-2014 01:54 PM
Adjusting Washer Spray Nozzle? Munkey 1999 to 2016 Super Duty 4 11-06-2010 01:04 AM
clogged windshield washer nozzle?? glmf 1 1999 to 2016 Super Duty 3 08-01-2003 01:26 PM
Tags
150, 1966, 2005, 87, 97, bronco, f150, ford, nozzle, remove, sprayer, washer, window, windsheild, windshield
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
