F150 - 16 Pin Reverse Camera Mirror - Question On Input
Answering my own thread :
It seems to be 12v.
09 rear view camera - Page 29 - Ford F150 Forum - Community of Ford Truck Fans
It seems to be 12v.
Ok...another question.
To get the autodimming to work, am i correct in saying that i need to put 12v to pin 15 or 11 ? and ground to 15 or 11 ?
Edit : From google : http://club4g.org/board/audio-lighti...tml#post530033 pins 11/15 don't seem to be needed.
pin 2 is activated by the reverse wire. it's positive switched
auto dim doesn't require anything special. just the power/ground/reverse trigger to be connected. the mirror does everything else internally once power is applied. the reverse trigger tells it to quit dimming at night-time so you can back up as needed
your OEM rearveiw mirror hopefully will have 3 wires. a hot wire, a ground, and a reverse trigger (green w/ brown stripe)
connect that green with brown stripe to Pin #2
You need to connect the following wires to make the mirror work.
here is a slightly easier schematic to use. hope it helps
Pin #1 - Power
Pin #2 - Reverse trigger
Pin #3 - Ground
Pin #8 - Camera +
Pin #16 - Camera -
Pin #1 - Power
Pin #3 - Ground
Pin #8 - Camera +
Pin #16 - Camera -
the camera is powered whenever the truck is running. just like the factory installed ones are.
the reverse trigger wire (green w/ light brown) tells the mirror to turn on the LCD display and show what the camera is outputting
I spent about 3 days figuring this mod out. It's awesome once it's working, but a major PITA to go blindly into. Hope I can help you avoid my growing pains
I've got a sync mirror, so the earlier 16 pin type. I might try my cell phone mic through it, not sure yet.
If i don't wire the compass wires up will it just not be there ? i.e. no error messages on it. I don't want / need it. I already have a compass display on the roof console.
G
G
they simply sense the cardinal directions and send it to the LCD in Instrument Cluster (if equipped on vehicle)
sounds good then
hasteranger
06-30-2019 09:51 AM
michaelg10
09-09-2016 05:59 PM
ExpeditionJim
04-24-2011 12:26 PM
Billy Hell
12-30-2007 07:38 PM
