'93 F-150 SAS and Front Leaf Swap - Ford Truck Enthusiasts Forums
Old 03-18-2012, 06:19 PM
mkuieck mkuieck is offline
mkuieck is starting off with a positive reputation.
I am getting ready to do a straight axel swap and front leaf spring conversion on my '93 F150 Reg Cab Short Bed. I have already acquired a D44 high pinion front axel and a set of late 70's F250 highboy front leaf springs. The best plan i have come up with so far is just to get a set of front leaf hangers for a late 70's F250 and fit them to my frame.
May also be relevant to mention that I am putting a D60 in the rear and putting swapping out the L6 under the hood for a carburated 351. Planning on running 35 inch tires and have 3inch body blocks as well as lift blocks that I planned on fitting accordingly to the rear axel to match height at front axel.
Anyone have any insight on this type of project or any ideas other than what I have listed as to how to approach this project?
Old 03-18-2012, 06:30 PM
rla2005's Avatar
rla2005 rla2005 is online now
rla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud of
Tons of info from the Bronco crowd: The GOD of leaf SAS thread - FSB Forums
How do you plan to run your speedometer?
Old 03-18-2012, 07:38 PM
Not sure on the speedo. It wasnt working long before i took the truck off the road to start this project anyhow though. Never did figure out everything behind how the speedo works on these trucks either. I have been told by some that it reads from the tranny and been told by others that it reads from the rear diff. Would welcome any insight into that as well although it is not priority at the moment. Thanks for the suggestion for FSB.
Old 03-18-2012, 07:51 PM
tjc transport's Avatar
tjc transport tjc transport is online now
i ain't rite
tjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputationtjc transport has a superb reputation
93 speedo will read off the VSS in the rear axle. the D-60 rear will not have provisions for a VSS
Old 03-18-2012, 07:57 PM
rla2005's Avatar
Quote:
X2
Old 03-19-2012, 10:34 PM
yeah ive seen the wires running to my 8.8 currently on the truck. makes sense. thanks.
Lift Blocks jtapal 1973 - 1979 F-100 & Larger F-Series Trucks 20 01-07-2016 11:24 PM
1966 f100 to f350 coversion 1966-pickup 1961 - 1966 F-100 & Larger F-Series Trucks 17 06-03-2015 10:31 PM
F-100-600 Rear Leaf Springs Outlaw56 1948 - 1956 F1, F100 & Larger F-Series Trucks 11 03-18-2015 10:45 AM
1972 f250 highboy axel Feardeere7 1967 - 1972 F-100 & Larger F-Series Trucks 9 01-22-2013 08:11 AM
Leaf spring question's 93f250tn 1987 - 1996 F150 & Larger F-Series Trucks 29 07-18-2011 11:32 AM
Tags
1987, 87, 93, axle, bronco, convertion, f150, ford, front, interchange, kit, leaf, sas, spring, springs
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
