Overdrive light flashing when decelerating
Old 03-17-2012, 02:37 PM
pruett365's Avatar
pruett365
pruett365 is offline
My 4x4 1993 F250 overdrive light flashes when I let off the accelerator pedal and stops flashing when I accelerate. I believe it is an AOD. Any ideas anyone? Thanks.
Old 03-17-2012, 05:24 PM
rla2005's Avatar
rla2005
rla2005 is offline
Received 1,157 Likes on 915 Posts
The F250 and F350 never came with an AOD from the factory. Yours is an E4OD.
Your best bet is to check for codes: Fuel Injection Technical Library » How To Run a Self-Test
Or purchase one of these to display codes: Equus 3145
Old 03-18-2012, 10:46 PM
pruett365's Avatar
pruett365
Thank you. I had a strong suspicion that it was an E40D.
I did take the pickup down to the local parts store and had them run their diagnostic scanner which couldn't seem to pull anything from the port.
Old 03-18-2012, 10:48 PM
FORDF250HDXLT's Avatar
FORDF250HDXLT
FORDF250HDXLT is offline
is your tach going dead at idle?
Old 03-18-2012, 11:14 PM
rla2005's Avatar
rla2005
rla2005 is offline
Clean the pins in the connector. Use some contact cleaner. Sometimes you have to get a little more aggressive, I use a small screwdriver from time to time.
Old 03-18-2012, 11:18 PM
pruett365's Avatar
pruett365
You know, I think the tach is going dead at idle. I'll check again tomorrow.
Old 03-19-2012, 09:34 PM
pruett365's Avatar
pruett365
The tach does go dead at idle.
I don't know if it is related but when I step down hard on the accelerator pedal to pass or climb a hill while O/D is on, the transmission downshifts too low and tachs-out without upshifting. It will only upshift if I turn off the O/D.
scav_one19
06-26-2013 08:15 PM
Zack12
12-16-2012 08:02 PM
mblanken881
19
04-10-2009 08:39 AM
zed326
1997-2006 Expedition & Navigator
01-13-2009 08:19 AM
skrinar70
10-26-2007 08:46 PM
Quick Reply: Overdrive light flashing when decelerating
