high performance bullnose trucks?
Old 06-12-2012, 05:55 PM
91dirtydiesel's Avatar
91dirtydiesel
91dirtydiesel is offline
Found a frame donor, 84 f150 shortbed. Paid 350$ for it. Just needed a battery and runs pretty well! Too bad the body is rough. Anyone looking for a 6" lift kit!?
  #47
Old 06-12-2012, 06:01 PM
91dirtydiesel
Engine is in the hands of nmb2 now who is fabbing the turbo kit
  #48
Old 08-31-2012, 02:37 PM
TheTowingCowboy's Avatar
TheTowingCowboy
TheTowingCowboy is offline
I found this searching for cummins swap info, and I wanted to bring up something I heard once, instead of doing a P-Pump conversion, why not get one of those Caterpillar V pumps? Save some space with that. Also that S366 looks to me like a turbo for a Cummins (The third gen cold side gave it away) And it will spool way quick on that 7.3 compared to how it would spool on a 5.9 so be careful.
  #49
Old 08-31-2012, 02:40 PM
91dirtydiesel
It's getting a bosch p7100 series pump....
  #50
Old 08-31-2012, 05:30 PM
Sw1tchfoot's Avatar
Sw1tchfoot
Sw1tchfoot is offline
Do you have a geartower made up to mount the pump to?
You could probably make a little $$$ by selling a mounting kit for the P7100.
  #51
Old 08-31-2012, 05:46 PM
91dirtydiesel
Waiting to get my engine back then mock up will begin... Racinndrummin does a lot of custom fab work so he would be the one to ask...this pump flows 340cc as is...too much for any old idi without some other supporting mods....we will see how she reacts LOL
  #52
Old 08-31-2012, 06:03 PM
CountryBumkin's Avatar
CountryBumkin
CountryBumkin is offline
Off topic - but - How do you load that trailer? It looks like the axle width on your Truck is wider than the tandum axles on your trailer?
  #53
Old 08-31-2012, 06:11 PM
91dirtydiesel
if it was any wider it wouldnt fit...tires barely squeezed through. i was borrowing it from my buddy....he uses it for his wheeling rig bronco
  #54
Old 09-01-2012, 10:27 AM
TheTowingCowboy
That P-Pump looks like its missing the govenor housing and AFC, also its going to be a trick to mount that and time it, cause if the wrong gear is used well may not run right lol. I wouldnt try it, but thats cause am not to far into the 'One off' world. Also if I were to really guess that looks like a 8300 series pump, which is a plus.
  #55
Old 09-01-2012, 10:38 AM
91dirtydiesel
I know I can get complete governor / afc for 375$...pretty sure it's a late 7000 series, it's timed off of cyl #8. The idi cam/pump gear is already ran 1:1 so it shouldn't be too bad. One thing tho I'm really trying to figure out is if this pump takes a oil supply (I've read yes, and I've read no)
  #56
Old 11-19-2012, 03:11 PM
91dirtydiesel
hey fellas, question about the truck... are there any aftermarket dashes or guage clusters available? what about wiring harnesses?
here is a pic of it, we ran into a little snag on the Ppump but its going in to get calibrated to our needs
  #57
Old 11-19-2012, 06:01 PM
Diesel_Brad's Avatar
Diesel_Brad
Diesel_Brad is offline
Nothing aftermarket for these trucks, you be making everything
  #58
Old 11-19-2012, 07:02 PM
86LariatXLT's Avatar
86LariatXLT
86LariatXLT is offline
You still have lift that kit? :P If so I'd be interested.
  #59
Old 11-19-2012, 11:44 PM
91dirtydiesel
That's what I figured...Thot I'd ask. Thanks
Sold it and got f'd on shipping it. Lol don't ever try to ship something without knowing exact weight
  #60
Old 11-19-2012, 11:50 PM
86LariatXLT
Lol. Well thanks anyways
Ford_Six
104
06-05-2017 04:55 PM
hail destroyer
01-05-2017 07:03 AM
Pele
18
08-30-2007 12:03 PM
Greywolf
General Diesel Discussion
01-05-2006 12:08 AM
72fordhiboy#1
Offroad & 4x4
03-30-2005 10:33 AM
Quick Reply: high performance bullnose trucks?
