high performance bullnose trucks? - Page 3 - Ford Truck Enthusiasts Forums
  #31
Old 03-27-2012, 07:16 PM
91dirtydiesel's Avatar
91dirtydiesel 91dirtydiesel is offline
91dirtydiesel is gaining momentum as a positive member of FTE.
Quote:
Originally Posted by kedwinh View Post
Besides that it'll be something different than everyone else has..
exactly!
  #32
Old 04-03-2012, 12:10 PM
  #33
Old 04-19-2012, 12:32 AM
  #34
Old 04-19-2012, 12:33 AM
next is find a short bed, and find a big bearing 9" rear.....and of course engine build
  #35
Old 04-19-2012, 05:28 AM
Diesel_Brad's Avatar
Diesel_Brad Diesel_Brad is offline
Diesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud ofDiesel_Brad has much to be proud of
Why did you cut up the frame? Why not of just shortened it 16"?
  #36
Old 04-19-2012, 09:57 AM
fiftyfordfloored's Avatar
fiftyfordfloored fiftyfordfloored is offline
fiftyfordfloored is gaining momentum as a positive member of FTE.
Quote:
x2, Looked like a decent frame too...
  #37
Old 04-19-2012, 10:08 AM
1/4" thickness vs 1/8" thickness... The 350 and 250hd measured in at 1/4 thick and a lot beefier, 250's were about 3/16" thick and 150's were 1/8" thick. So we got a lighter frame. Waiting on guy to strip it down
  #38
Old 04-20-2012, 05:30 AM
If you want light, go buy an 1980 frame
  #39
Old 04-20-2012, 10:25 AM
1986F150six 1986F150six is offline
1986F150six is a splendid one to behold1986F150six is a splendid one to behold1986F150six is a splendid one to behold1986F150six is a splendid one to behold1986F150six is a splendid one to behold1986F150six is a splendid one to behold
Diesel_Brad,
Swiss cheese?
  #40
Old 04-21-2012, 08:24 AM
Quote:
Originally Posted by 1986F150six View Post
Diesel_Brad,
Swiss cheese?
Yup. I been running one in my pulling truck for over 10 years with about 400HP to the tires. I have broken everything BUT the frame. My one ton 4wd, 429C6 and me in the truck with FULL sheet metal and interior only weighs 5200
  #41
Old 04-27-2012, 01:20 PM
EffunFiddy's Avatar
EffunFiddy EffunFiddy is offline
EffunFiddy has a good reputation on FTE.EffunFiddy has a good reputation on FTE.
I had found a company a couple years ago that made fiberglass fenders only, but I can't seem to locate them.
http://usbodysource.com/
Not sure what you would think of a one piece front clip, seems like it might be a bit of a pain. The hoods don't seem too badly priced though. Haven't looked at Harwood just yet, but I hear they're good to deal with.
  #42
Old 05-14-2012, 06:16 AM
Cha1se's Avatar
Cha1se Cha1se is offline
Cha1se is starting off with a positive reputation.
What transfercase do you have?
Sorry to thread hi-jack, but I've just ordered a set of CHI 2V 190cc heads for mine. My bottomend is cleveland, storked to 4" and bored .040"
I'm just about to put my NP208 back together, and the tiny little teeth on the plate that drives the annulus looks like it's gonna be the frst thing to die.
Cheers,
Chaise.
  #43
Old 05-15-2012, 05:39 AM
I have been running a 1356 for 16 years in the truck. Broke it ONCE at 350,000 miles on a hard clay track(stretched the chain). Went to the junk yard and bough a used one for $100 and been using it since
  #44
Old 05-15-2012, 07:26 AM
Cha1se's Avatar
Excuse my ignorance, but I'm only new to these things.
I dont know what a 1356 is, I'll do a search, do you have a thread on your ride?
  #45
Old 05-15-2012, 02:59 PM
84-6.9L's Avatar
84-6.9L 84-6.9L is offline
84-6.9L is gaining momentum as a positive member of FTE.84-6.9L is gaining momentum as a positive member of FTE.
He's refering to the BorgWarner 1356 transfer case. It came stock in most 87 and up Ford 250's and 350's.
"Modernizing" My 96 OBS F350 96OBSRedTruck 1987 - 1996 F150 & Larger F-Series Trucks 5 12-12-2015 07:32 PM
Spring mod question for guys who have built their own leaf spring packs pirate4x4_camo Excursion - King of SUVs 34 09-12-2015 05:53 PM
Help with truck value grandpa.e 1973 - 1979 F-100 & Larger F-Series Trucks 9 02-14-2014 12:12 PM
74 f150 coil spring size and suspension help ! 74f150$$$$$ 1973 - 1979 F-100 & Larger F-Series Trucks 1 05-01-2013 04:26 PM
Actual cost of maintenance on the diesels Passport 6.7L Power Stroke Diesel 80 10-08-2012 10:11 AM
Tags
1983, 33, bronco, bull, bullnose, cab, diesel, explorer, f250, ford, frame, mount, nose, truck, trucks
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
