'83-94 IDI Diesel Parts - Radiator, Mounts, Trans, P/S Box, Misc.
Category: Accessories
Price: $0
Private or Vendor Listing: Private Listing
Part fits (you may select multiples): Fit, S2000, FCX, Motorcycles, Hybrids
Item Condition: NJ
Engine: Part suitable for diesel truck
# of Rows - 4
Core Height - 15 9/16"
Core Width - 36 15/16"
Core Depth - 2 3/8"
Inlet Header - 3 1/2" x 37 1/2"
Outlet Header - 3 1/2" x 37 1/2"
Inlet - 1 7/8"
Outlet - 2 1/8"
Trans Cooler - 12" (Concentric)
- 1983-94 IDI Motor mount frame perches (obsolete) - Media blasted, primed, painted chassis black. These are in great shape. I will include the old hardware (junk) as a reference for the new hardware. - $75, will ship.
- Power Steering box in good shape, came from a '93 F350 with 87K on the clock; $80 obo. Pitman arm needs to be removed (it was torched in half), and yours installed. Listed to fit the following:
- '80-97 OB F-Series & Bronco (All Models)
- '82-95 Econolines
- '91-94 Explorers & Mazda Navajo
- '83-97 Rangers
- '94-97 Mazda B-Series
- Serpentine Accessory Drive for IDI Diesel; complete setup with tensioner, all pulleys, brackets, alternator, power steering pump, vacuum pump and all bolts. Alternator and vacuum pump pulleys are shot. - Best reasonable offer.
- A/C Compressor Delete Pulley w/ Bracket and bolts. - $20
- Transfer case out of a '93 F350 w/E4OD (no VSS mount in case), manual case, believe it's an NP-208F, works good by hand, goes through the gears, nice. - $100 obo
- IDI Pattern C6 4X4 transmission; still in the truck, clean fluid, was in excellent running condition before the engine was pulled. Truck has 176k, no idea if the trans is original but it appears the converter is newer (painted bright blue), and I just installed a brand new neutral switch (included). - $400 obo
Stuff has to go, so shoot me an offer. Everything located in 08833; will ship smaller stuff for extra.
Hi my name is Henry.....how much for the frame perches shipped to Miami FL?....I´m swapping a 6,9L engine into my Bronco...
Would you have an oil cooler in good working conditions?
Thanks
Henry
Thanks
Henry
Call it $80 shipped... You pull the cooler apart yet? A lot of times all you need is to get them apart and replace the O-rings.
Thanks
Henry
PD: if you know any store where to get new parts like filters, belts etc....it would be great......I don´t know where to get diesel stuff....My Bronco is a 400" so it´s all gas!!
Hi man....this parts a re for a friend in fact...so I´ll tall him the price and I´ll let you know as soon as I know......About the cooler I think is broke in one of the aliminium ends....I´ll tell him to check again.Do you accept paypall?
Thanks
Henry
Thanks
Henry
Yes, I'll accept PayPal, so long as you cover the fees. I also take money orders. Let me know. Thanks!
You should be able to pick up most any Diesel parts from your local NAPA. That's where I get most of my parts from. Oil filter should be a 1742, fuel filter should be a 3811 for a 6.9L. Belts they can look up. RockAuto is also an option...
baileybilt
08-10-2019 02:59 AM
Uni Moe
09-29-2014 03:07 AM
kjgibson2
05-16-2012 08:18 AM
mark914
13
03-20-2008 09:42 PM
6.9l, 7.3l, 73, 94, accesory drive, c6 4x4, diesel, f250, ford, idi, motor mounts, np208, radiator, transfer case, transmission
