77 4x4 front end rebuild - Ford Truck Enthusiasts Forums
Old 03-18-2012, 11:54 AM
Famousamos Famousamos is offline
Famousamos is starting off with a positive reputation.
Hey guys, my truck is in desperate need of some front end work. The steering has lots of play in it and is very loose. Ive found a C-Bushing kit at Bronco Graveyard, what else is needed to complete the rebuild. I won't be doing the work, only purchasing the parts.
Thanks
Old 03-18-2012, 01:01 PM
74ford4x4 74ford4x4 is offline
74ford4x4 is starting off with a positive reputation.
I'd replace the tie rod ends and ball joint to.
Old 03-18-2012, 01:41 PM
Thesteeleboy's Avatar
Thesteeleboy Thesteeleboy is offline
Thesteeleboy is starting off with a positive reputation.
On all my 1977 F150's, I changed the tie rods over to 1978. I would hate to guess how many 1977 tie rods Ive bent rock crawling and getting wild, due to the fact that it comes new with a bend in it. That is the week link in a 77.
Old 03-18-2012, 02:36 PM
Thanks for the tips, I figured on replacing all the parts mentioned. Just didn't want to miss anything.
Old 03-18-2012, 08:42 PM
bamaf150's Avatar
bamaf150 bamaf150 is offline
bamaf150 is gaining momentum as a positive member of FTE.
Does the kit come with tracbar bushings? I'd bet money those are wore out too.
Old 03-18-2012, 08:50 PM
Yea, it includes C-bushings, trac-bar bushings and strut arm bushings.
Old 03-18-2012, 09:49 PM
You will also want to check the bolt that secures the track bar to the axle and make sure the bolt hasn't worn, or the hole in the axle tube is still tight on the bolt. They tend to wallow out.
Old 03-18-2012, 10:54 PM
HIO Silver's Avatar
HIO Silver HIO Silver is online now
HIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud ofHIO Silver has much to be proud of
Quote:
2X.. change over to the 78-79 T-style drag link and tie rods.
Poly shock eye bushings and poly tie rod boots are worth considering.
Old 01-20-2013, 04:38 PM
gfx4t gfx4t is offline
gfx4t is starting off with a positive reputation.
If your slack problem isn't resolved after rebuild, change out the steering gear box also.
Old 01-20-2013, 05:46 PM
77&79F250's Avatar
77&79F250 77&79F250 is online now
Used OEM parts guy
77&79F250 has a brilliant future77&79F250 has a brilliant future77&79F250 has a brilliant future77&79F250 has a brilliant future77&79F250 has a brilliant future77&79F250 has a brilliant future77&79F250 has a brilliant future77&79F250 has a brilliant future77&79F250 has a brilliant future77&79F250 has a brilliant future77&79F250 has a brilliant future
Ck the rag joint and the steering shaft, and wheel bearings since you are right there.
"Red Head" steering had a great rep as far as steering boxes.
http://www.google.com/url?sa=t&rct=j...41248874,d.aWM
front end rebuild kits?? mudrat025 1994.5 - 1997 7.3L Power Stroke Diesel 5 08-05-2016 07:15 PM
94 front end rebuild kit 4x4 Fryertuck 1987 - 1996 F150 & Larger F-Series Trucks 4 05-26-2016 08:40 PM
Front end rebuild. 87F250Lariat 1987 - 1996 F150 & Larger F-Series Trucks 5 06-28-2010 07:48 PM
79 Ranchero Front Suspension Rebuild 79rancher_boy Ranchero & 1961 - 1967 Econoline 6 10-10-2007 08:41 AM
front end identification Ford_250 Offroad & 4x4 12 03-11-2006 08:54 AM
Tags
1977, 1987, 4x4, bent, drag, end, f100, f150, ford, front, kit, link, loose, rebuild, rod, tie
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
