96 F250 351W hard starting - Ford Truck Enthusiasts Forums
Old 10-16-2002, 11:07 AM
70mach1 70mach1 is offline
70mach1 is starting off with a positive reputation.
Post 96 F250 351W hard starting
I have a 96 F250 351W/auto 4x4 with just over 46k on it. It is used for pulling a landscape trailer full of equipment (about 3500-4000lbs total) mostly around town.
The truck doesn't get much highway use except for a 40 mile round trip every other week (without the trailer).
The truck starts fine the first time in the morning and I will drive a couple miles to the first customer. The truck could sit for anywhere from 1/2 hour to 3 hours before starting it again but that's when the problem starts. The truck will take anywhere from 1 to 3 tries to start. It cranks fine and sounds like it might start but doesn't. Turn the key again and if the truck starts it blows smoke. The smoke (to me) smells and looks like a problem with too much fuel.
The oil was changed 2500 miles ago and the truck does not need any so I feel confident the smoke has nothing to do with burning oil. Also the truck has recent spark plugs, cap and rotor.
Any feedback on this problem would be appreciated. I am wondering if it is some sort of intermittant injector problem. Any ideas?
Thanks for your help!
96 F250 XLT S/C 4x4
70 Mach1 351C Shaker
Old 10-16-2002, 06:06 PM
edenroadmaster edenroadmaster is offline
edenroadmaster is starting off with a positive reputation.
does the check engine light flash or come on?
edenroadmaster
Old 10-16-2002, 07:34 PM
heathdaily heathdaily is offline
heathdaily is starting off with a positive reputation.
I think I just fixed this prob on my 92 4.9 f-150. The throttle body gasket had sucked in. Looks like poor design to me. The 351 throttle body should be identical with larger bores. Try spraying carb cleaner where the throttle body meets the intake. Should make rpm jump. Sure did on mine.
Old 10-16-2002, 10:08 PM
I don't remember seeing the check engine light on. I will watch for that more closely tomorrow when I use the truck.
Thanks
Old 10-16-2002, 10:13 PM
I should have some carb cleaner on the shelf in the garage. I'll give it a try tomorrow. What problems or symptoms did your truck have?
Thanks for the suggestion. I'll let you know what happens.
Old 10-16-2002, 11:42 PM
JSS JSS is offline
JSS is starting off with a positive reputation.
Check out in the "Fuel Injection, Carburation and Fuel System" forum on this website where I posted a (long winded!) response to "92 F150 Fuel Injectors" on 10/12. I had a similar problem with my 95 F250 with 351W. It was a combination of bad fuel pressure regulator and leaking fuel injectors.
A friend of mine with a 94 F250 had the same problem also caused by leaking fuel injectors, but we both had about 110,000 miles on our engines compared to your relatively low mileage. The light truck fleet where I work at is exclusively Ford (holds up the best in mining environment!) and the mechanics say that they often start seeing the leaking injectors on them around 100,000 miles too. The only things these Fords don't hold up to is open range cattle...
Old 10-17-2002, 08:49 AM
JSS,
Thanks for the information. I read your response to "92 F150 Fuel Injectors". I think my next step is going to be a fuel pressure check and maybe pulling the spark plugs to see if any are getting wet with fuel. After that possibly rebuilding or replacing the injectors.
I'll let you know what I find.
Thanks again.
Old 10-17-2002, 08:51 AM
michaelskerrett michaelskerrett is offline
michaelskerrett is starting off with a positive reputation.
hard start but runs great!? rmgraw351 1999 - 2003 7.3L Power Stroke Diesel 9 11-15-2015 07:49 PM
2007 Blowing white smoke after oil change. mayhem2k7 6.0L Power Stroke Diesel 3 04-24-2015 07:45 PM
53 progress update with pics 71mach351 1948 - 1956 F1, F100 & Larger F-Series Trucks 1 08-24-2014 04:34 PM
Oil out exhaust pipe? craziejoker 6.0L Power Stroke Diesel 39 01-16-2014 06:32 PM
1999 Explorer no power/ runs rough 99 4.0 Explorer, Sport Trac, Mountaineer & Aviator 3 07-09-2003 08:24 AM
Tags
351w, hard, start
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
