My Nitto Terra Grapplers and air pressure
So I bought a set of 295-70-18s for my 04 FX4...they do look good, but they aren't the quietest tire around... and if I hit a patch of rough pavement, the rear end bounces around. This gets a little spooky going around corners...!!! I checked the air pressure...the tires has 50 psi. I dropped it to 40, and that helped somewhat, but the shake and shimmy is still there. on rough pavement.
Anybody else have that problem? What pressure are you running? I'm considering going to 30-35 psi but I don't want to mess up the tires.
Thanks for the replies. I got to thinking right after I posted this that the shocks (original) might be the problem, and since it's raining kitties and puppies here in Socal and I have a nasty cold , I haven't checked to see the load rating on the tires. I actually never gave the load rating a thought when I bought the tires...my mistake.
My truck is low mileage...right at 51,000 miles...all on the original Goodyear Wrangler tires. I'm just getting ready to get the injectors and throttle body cleaned...
Coskid is right they are E rating for sure. I run my trail grapplers at 40 psi, and I don't notice anymore bounce than before. My truck has 45k on it now and i'm pretty sure that the shocks have never been changed. I too took the original goodyear wrangler tires off my truck when I bought these new ones. They would have made it a little longer, but when the new tires came in, I couldn't wait to put them on. I'd be willing to bet that your problem is in the shocks not the tires. Nitto makes a really good tire.
