Go Back   Ford Truck Enthusiasts Forums > Regional Chapters > Western Region > Oregon Chapter
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Oregon Chapter Join Chapter, Leader: Fabmandelux
  #1 (permalink)
Old 03-17-2012, 08:08 PM
PDXF250 PDXF250 is offline
Garage is empty, add now
PDXF250 is starting off with a positive reputation.
f250 83 7.5 (won't start now)
Here's the skinny on my beast.
1983, F250 7.5, automatic.
It wouldn't pass through DEQ, wrong carb.
Replaced carb. Ran fine. But not having tags, I didn't drive it. But I know it ran fine. As it's not my main driver, I haven't necessarily been too concerned about it.
I had a mechanic adjust the carb, and it ran strong. Moved it out into the street probably a month ago (?). It has plenty of gas, and sits in the street nose down.
Today i decided I would try to start it. It turns over plenty fast, but doesn't catch.
If I put starter fluid in it, it will turn over and catch and run until it dies when the starter fluid obviously dies off.
I'm wondering if it's a fuel pump or fuel filter issue. The filter occasionally hums when I start (and sometimes will stay humming after i turn off the truck), but mostly doesn't hum.
Earlier, when I was fixing the truck (from a previous operation) I tried replacing the fuel pump (?) solenoid (? I think thats the name...little green box in the engine compartment), but that didn't make a lick of difference.
I think once I get the beast fixed, passed through DEQ, I'm going to sell it. It's not like I dislike the truck, it just turned out I don't need it like I thought I would.
Any suggestions (from my vague descriptions)?
I'm hoping it's fuel pump, because it would make sense. Could it be the sending unit? I know both my tanks barely read accurate (and I just remembered that the previous owner said that when the truck is using the BACK tank, that it would not work great on a hill unless you had a majority of a tank in it).
dan
  #2 (permalink)
Old 03-18-2012, 10:05 PM
Brown Falcon's Avatar
Brown Falcon Brown Falcon is offline
1995 Ford F-350
Brown Falcon has a great reputation on FTE.Brown Falcon has a great reputation on FTE.Brown Falcon has a great reputation on FTE.Brown Falcon has a great reputation on FTE.Brown Falcon has a great reputation on FTE.Brown Falcon has a great reputation on FTE.
Easy way to test the fuel pump (I'm assuming it's electric since it hums) would be to disconnect the fuel line and stick it into a bucket or something to catch the fuel, then have someone turn on the key to see if it's pumping...
__________________
Brownie (Evan) Ooh-Rah! Once a Marine Always a Marine Oregon Chapter Member
'95 F350 CC 4x4 - 7.3 PSD, 190k, Built E4OD, SRW Conv, 4x4 Conv, Rosewood Stage I's, PHP Chip, 6637 Intake, 3" DP, Lost Kitty, 4" Exhaust, 3" RSK, 38 gal rear tank, fuel vent mod, 140v IDM, HPX, FPR Shim, 3.55 gears
'10 Escape, 200hp 3.0 V6, 4x4 - Stock
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
