You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
I hope someone here has an early Ford Parts book that could decipher these early ('57-'60?) 9" Ford rearend part numbers:
The carrier casting: WAB 4025A
The differential castings: WAC-4205A, WAC 4206A
Pinion Support Flange Stampings: WAA 11 4668B
Stamped on the ring gear: WAA-4210-A OR24 916 Shift No.2 FoMoCo USA
I was surprised to be able to make out on the tag: 3.70
The things I'd like to determine are:
A) What model car/truck this center section likely came out of;
B) What size side bearings it would have (3.063 or 2.89)
C) Is the differential is a limited slip or open
D) If the differential would accept 28 spline axles or ???
Thanks in advance of any & all assistance, Guys!
BarnieTrk
__________________ - 4WD '05 Excursion, Eddie Bauer, 6.0 Diesel; Company Vehicle
- 2WD '65 F100 short box, 390" FE, T-18 4spd; rusty-but-trusty
- 2WD '65 F250 long box, 390" FE, T170FT 4spd OD; clean & stout
- 2WD '94 Ranger XLT, regular cab, 139" (2.3L) 4-cyl, 5spd; 307+K miles & still kickin'....
