5.0 runs rough with no power
03-17-2012, 06:31 PM
on
i have a 90 f150 with the 302 auto. i was driving home from work and the truck shut off, it took 10 mins to start back up and when it did it ran like crap. i had orilleys run a test on it and the egr valve needed replaced. i did and no luck, i replaced the plugs wires cap and rotor, i also fixed the oil leaks (valve cover gasket and oil pan gasket), at this point i dont know what to do, has any one had the same problem
03-17-2012, 08:08 PM
on
Have you checked for codes or checked the the fuel pressure. The fuel pressure should be between 35-45psi.
03-17-2012, 08:17 PM
on
there was an egr code but that is gone now, there is nothing else, fuel pressure is at 42 psi, i am going to do a compression test, do you know what it should be at
03-19-2012, 12:23 AM
on
try
try the control module on the distributor, see if that is messing up.
03-19-2012, 12:38 AM
So now does it run poorly all the time or just when warm?
03-19-2012, 01:25 AM
on
It runs like crap as soon as it's started. Would the control mod do that
beatupford
07-20-2021 09:28 AM
odeent
1999 to 2016 Super Duty
07-23-2019 03:53 PM
rodsideremover
28
05-26-2015 05:09 AM
Tater7633
16
05-08-2015 10:06 AM
maniac2313
08-21-2011 11:28 AM
1986,
50,
backup,
engine,
f150,
f250,
ford,
poorly,
powered,
ride,
rough,
runs,
truck,
vbulletin,
windsor
