Go Back   Ford Truck Enthusiasts Forums > Diesel > Pre-Power Stroke Diesel (7.3L IDI & 6.9L)
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 03-17-2012, 05:49 PM
RCrawler's Avatar
RCrawler RCrawler is offline
Garage is empty, add now
RCrawler is gaining momentum as a positive member of FTE.RCrawler is gaining momentum as a positive member of FTE.
OE Dana Spicer ball joints on a Dana 60
Has anyone replaced ball joints using Dana parts? The original joints had dust seals on the upper and lower. The replacements don't have them but the lowers will still fit.
Leave them off?
Jason
__________________
'12 Dodge 3500 crewcab 6.7 HO, Not Stock!!
'93 F350 CC 4wd 7.3 ZF and a ton of miles
'69 Bronco SEFI 5.0, NP435, geared, locked...
Honey badger don't care...
  #2 (permalink)
Old 03-19-2012, 04:10 PM
redmondjp's Avatar
redmondjp redmondjp is offline
1990 Ford F-350
redmondjp is gaining momentum as a positive member of FTE.redmondjp is gaining momentum as a positive member of FTE.
Quote:
Leave them off? Jason
Are you talking about those stamped sheet metal collars that fit around the bottom of the rubber boot? If so, I'd use it if it fits.
__________________
1990 F-350 XLT CCLB SRW 460 5spd 4x4 3.55LS, 98K miles, mostly stock
sent from my iKeyboard
  #3 (permalink)
Old 03-19-2012, 10:49 PM
RCrawler's Avatar
No. The actual dust boots. My original BJ's were really worn out, so I had nothing to compare with. The new joints both had seals on them, but no boots. I was able to install the lowers and fit the boots. But no go on the uppers. I installed them without, figuring that the seals should keep the majority of dirt out.
Thanks,
Jason
__________________
  #4 (permalink)
Old 03-20-2012, 12:33 AM
redmondjp's Avatar
1990 Ford F-350
OK, stupid me, I was thinking of the 2WD ball joint dust boots, not the ones used on the 4x4, D'op!
You should be fine.
__________________
Tags
2002, 4x4, 60, 73, ball, dana, danaspicer, diesel, f250, ford, joint, joints, press, spicer, year
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
