Troubleshooting loss of coolant (evidence of white residue around cooling system components (Degas))
Old 03-23-2015, 11:58 AM
Per4mance's Avatar
Per4mance
Per4mance is offline
Me personally,I won't tow with a tune. that being said I'd put a "T" and run a pressure ck.....that the only good way to tell if the headgasket is "NG"
  #32
Old 03-23-2015, 12:59 PM
billbot's Avatar
billbot
billbot is offline
Agree with testing coolant pressure and not towing with tunes
  #33
Old 06-18-2015, 10:53 AM
gimpnurse's Avatar
gimpnurse
gimpnurse is offline
I had a small coolent leak that would only show up at times. It finally quit leaking on it's own and so I have kept an eye on the level ever since. Any suggestions??
  #34
Old 06-18-2015, 11:17 AM
billbot's Avatar
billbot
billbot is offline
Has any recent work been done on your truck? Sometimes the coolant system can get air pockets in it and as they work their way out, it can look like a coolant loss. Keep a very close eye on it, make sure when you take level measurements your truck is on an even surface and the coolant is cold. The level fluctuates quite a bit once it starts warming up.
Replace your degas cap, cheap and easy. Then go with pressure testing, as bismic describe on the first post.
  #35
Old 06-23-2015, 08:33 AM
gimpnurse's Avatar
gimpnurse
Yes, we did have some work done on the truck!
I will make sure to replace the cap and keep checking it very closely which is what I had been doing but it made me nervous since I did not know why the level was going down. I will follow your advice and make sure it is not something bigger going on. Thanks to all who have posted on this issue, it is appreciated so much by many more owners than you know!
  #36
Old 09-01-2015, 06:07 AM
bismic's Avatar
bismic
bismic is online now
Received 2,483 Likes on 1,722 Posts
Even though much of the information in this thread already comes from TSB 09 08 03, I thought I would attach the TSB for reference.
Also, here is a troubleshooting video from BulletProofDiesel on doing a ROUGH diagnosis of the EGR vs. head gasket failure via a degas bottle bubble test.
  #37
Old 01-01-2017, 11:41 AM
dlynes's Avatar
dlynes
dlynes is offline
Question
Originally Posted by npccpartsman
What's your temp spread after the truck is well up to operating temperature and a 5-10 mile 65mph steady cruise on level ground? If it's more than 15* doing that then you have an oil cooler problem.
Hello,
My truck under no load and incline and just slowly cruising around around my temps will differ by 15 degrees. There is no white smoke and no coolant in the oil and no oil in the coolant (per sending my oil off for testing). I replaced the degas top with a new OEM top. If I put the truck under load, my degas bottle will spray. Based on my symptoms what do you guys recommend me to test for and what do you think the problem might be?
I have driven the truck 700 miles and I have not gone thru much coolant. My brother was the one adding 2 gallons each month but that was in the hottest months of summer in Georgia and it was his work truck. Regularly pulled his Bobcat and tree debris.
  #38
Old 01-04-2017, 07:24 PM
dlynes's Avatar
dlynes
dlynes is offline
Originally posted by Bismic
Troubleshooting loss of coolant, evidence of white residue around cooling system components (especially the Degas cap)
Determine if the belt, the tensioner, and the water pump pulley can sustain the load of the vdf (fan) at 100% duty cycle without slippage: Look at the water pump pulley. If you find where the belt rides to be no longer black, but shiny and polished, that means that the belt has been slipping and that replacement of the belt, tensioner, idler pulley, and water pump pulley are warranted.
If the degas bottle is leaking you will see a white residue as it dries. This white residue is from the coolant. There are 4 likely causes for this
1. Leaks in the Degas bottle itself, weak cap or imperfections with sealing to bottle
2. Leaks in the coolant recirculation system (when checking for leaks, check the radiator hoses, heater hoses, EGR hose, Degas bottle recirculation and vent hoses, and the coolant filter system if applicable. Also check for a leaking seal around the water pump, block drain plugs, etc.
3. EGR cooler starting to leak. An EGR cooler leak can cause the Degas bottle to overpressure and blow coolant out the cap (venting). This is often times (but not always) accompanied by white smoke out the tailpipe, and coolant under the EGR valve when inspecting w/ the vehicle parked on a decline
4. Leaking headgaskets, typically from overboost. Leaking headgaskets can cause the Degas bottle to overpressure and blow coolant out the cap (venting).
TROUBLESHOOTING
Make sure that the hoses, degas bottle, and water pump gasket, block drains, etc. do not show obvious signs of leaking After driving the vehicle and getting it up to temp, park on a down slope (vehicle nose pointed down) and pull your EGR valve. Look for coolant under the valve in the intake. Maybe 25% of the EGR cooler leaks can be identified this way.Look for evidence of white smoke in the exhaust, and try to determine from smell if it is coolant. Also, white smoke from fuel will tend to rise and dissipate, where white smoke from coolant will tend to linger close to the ground.Check the Degas bottle for any imperfections or leaks. Sand (with an emery cloth) the top face of the degas bottle opening. Consider replacing the Degas bottle cap at this point (part # 9C3Z-8101-B). They are cheap. I recommend the OEM cap. It is a reliable component for the most part. If at any time the Degas bottle cap has relieved, Ford states that the spring could be weakened and it should be replaced.
Next, let the engine cool down (you want a cold system to do this test). Apply vacuum to the cooling system with the coolant at minimum level or 1/2 inch below minimum. Vacuum type cooling system fillers work well for this. Try Snap-on RADKITPLUSA 078-00592 or similar. You can also use an Actron CP7830 vacuum hand pump - get a good rubber stopper for plugging the degas bottle cap opening. A #9 rubber stopper will work just fine. You can tee into the hose that goes to the Degas bottle from the intake and apply at least 25" of Hg vacuum to the system. Let it sit like that. If the vacuum does not hold over 15 minutes (preferably 20 min) you then need to pull the EGR cooler and check it for pressure and vacuum - out of the vehicle. If you change the EGR cooler, change the oil cooler at the same time and flush the system thoroughly. It is possible to force coolant into a cylinder and cause a hydrolock by adding pressure to the degas bottle. For this reason the vacuum leak test is recommended to be done first. If the vacuum test above shows a leak, then it is time to do pressure and vacuum leak tests on the EGR cooler after removing it from the vehicle. This testing can be done by submerging the EGR cooler in a water bath. Air pressure applied to the EGR cooler (coolant side) will pass through any cracks and bubble up through the water. If you decide to do the pressure test on the degas bottle next, then be sure to evacuate the cylinders before operating the vehicle. My next suggestion (assuming the cold vacuum test passes) for diagnosis is this: Get yourself a good pressure tester (I understand that Autozone sells a kit that works well) and tee into the smaller lines going into the degas bottle from the intake, do not remove the cap. Pressure up the system, record the release pressure of the cap, and look for leaks in the degas bottle itself and around the cap. If you have any leaks at the cap before it reaches 16 psi, AGAIN check the bottle for imperfections and verify that the top face of the degas bottle opening is flat and smooth. You may be tempted to do this pressure test first, but remember, there is a small chance that a pressurization of the degas bottle could force coolant into a cylinder if you have a significant leak in the EGR cooler already. Even a new cap has a slight potential of being bad. If the cap leaks at 14 psig or below, replace it again with a new cap and repeat this test. Keep the pressure testing system mentioned above installed on your system and make sure your coolant level is at minimum. Loosen the cap on your Degas bottle and leave it loose (one round on the threads is good). Drive it until it gets up to temperature. Pull over and tighten your Degas bottle cap. Begin driving and carefully perform some WOT runs getting the engine to reasonably high boost - but not over 28psig. If you are tuned and do not have head studs, you may want to just drive normally during this test and not push maximum power, unless you are OK with installing head studs sooner rather than later. If the EGR cooler is good (or you have just replaced it) and you have seen pressure swings in the degas bottle as tested in the previous two tests, then it is likely that you have a leak in the head gasket(s). When replacing the headgaskets have the turbo taken apart and checked. The unison ring will typically be worn where the actuator runs. Fix the turbo as required. If you want to use aftermarket parts the BulletProofDiesel parts are good. The BPD EGR cooler is very durable and has a good reputation. The BPD air cooled oil cooler is great also, just expensive. Anytime you have a failed EGR cooler, you should seriously consider replacing the oil cooler. At a minimum - be sure your ECT/EOT deltas are 15 degrees F or less at WOT (fully warmed engine. If you don't have the means to diagnose this yourself, take it to a dealership/repair shop you feel comfortable with and have them test it.
FYI - The Lisle LIS20300 pressure/vacuum gauge will work (I believe it only goes to 14 or 15 psig though). O'Reilley's sells it.
Also - OTC 5613 Vacuum / Pressure Gauge Kit (0-15 psig)
Mityvac sells a 0-30 psig gauge and also does vacuum. It would be ideal: MVA6181
Mityvac
Mityvac MVA6181 MVA6181 - Compound Vacuum/Pressure Gauge
Lastly: KD Tools (0-15 psig) Model# KDS2521 and Actron CP7802 (0-15 psig)
Being that your temp spread occurs at WOT you do not have an oil cooler problem. You might have a bad cap and that's the first thing I'd change. I'd also do a pressure test on the cooling system. You may have an EGR cooler leaking but with your coolant temps staying in the range they are I'd not be willing to scream headgaskets yet.
yeah I'd suspect the cap. I'd replace the bottle too if it is old. If the sealing surface is uneven you will get leaks too.
  #39
Old 01-11-2019, 05:13 PM
BjornF16's Avatar
BjornF16
BjornF16 is offline
Updated video from post #36
nashaj
09-05-2017 07:09 PM
98wgefugfu3ebg
04-06-2016 08:56 PM
Buckbuster
6.4L Power Stroke Diesel
13
02-26-2012 09:30 AM
rocky1074
04-15-2010 08:19 PM
Quick Reply: Troubleshooting loss of coolant (evidence of white residue around cooling system components (Degas))
