Troubleshooting loss of coolant (evidence of white residue around cooling system components (Degas)) - Page 2 - Ford Truck Enthusiasts Forums
Old 03-02-2014, 06:31 AM
Disament's Avatar
Disament Disament is offline
Disament is starting off with a positive reputation.
The temp spread stays around 10* on highway. Honestly I cannot answer the question with entire accuracy.
In town with stop and go and "semi-rural" the spread is about 6* and often times less.
I'm hard on the X at times and am so on purpose to test the vehicle…I need to know my vehicles own failure points, weaknesses, etc. that need to be addressed as the second owner.
The SCT LiveWire (stock tune) is set to Performance and the max boost I have seen is 33.xx psi (once).
I want to clarify that I drive it just like I drive any other vehicle I own (regardless of it's size) within the laws of physics.
There has been absolutely no drag racing or anything of that nature but I do feel the need to stress the drivetrain, in my case anyway.
Old 03-25-2014, 10:56 PM
Champer11 Champer11 is offline
Champer11 is starting off with a positive reputation.
Same thing happening to me.
I made myself a pressure tester and T'd it into the coolant line.
WOT going up hills the pressure will spike to 16 and then fall back down once the cap releases.
Thinking head gaskets.
My temp deltas have always been spot on, <5 degrees while not towing.
Old 03-26-2014, 01:50 PM
billbot's Avatar
billbot billbot is offline
billbot is gaining momentum as a positive member of FTE.
My first thought would be HGs too. IIRC EGR cooler failure will be a more gradual increase in pressure, not a spike like you described.
Look on the bright side, now you can get your truck studded.
Old 03-26-2014, 05:23 PM
mlytc mlytc is offline
mlytc is starting off with a positive reputation.
Just noticed the telltale white residue around my degas cap. Took it off and when I put it back on it doesn't click when it gets tight, just a kind of thump instead. I put new HGs on it and had it studded less than 40k ago, sure am hoping its just a bad degas cap. If not, I don't see doing HGs again since the heads were replaced under warranty at 95k and I studded them, replaced the gaskets and did the EGR delete at 165k and I am now at 203k and it is venting again.
Not to mention replacing all 8 injectors at 197k because they were allowing fuel to seep into the oil and causing shutdowns.
Old 03-26-2014, 06:21 PM
billbot's Avatar
Yeah I'd suspect the cap. I'd replace the bottle too if it is old. If the sealing surface is uneven you will get leaks too.
Old 03-26-2014, 06:39 PM
Quote:
Bottle was replaced when I did the injectors and I talked to the guy that did the work and he doesn't remember putting a new cap on it. I'm hoping the old cap is the issue. If not, it's going through the Monday night "as-is" line at the auction.
Old 03-26-2014, 08:03 PM
bismic's Avatar
bismic bismic is offline
bismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputationbismic has a superb reputation
Make sure the cold coolant level is correct and carefully inspect the surface where the cap seals against degas bottle - sand it smooth if needed. I assume you are confident that the concentration is between 50% and 60%?
Old 03-26-2014, 10:31 PM
Quote:
To be totally honest, I'm not sure of anything at this point. Going to change the cap, sand as needed and check the concentration percentage and go from there.
Old 03-26-2014, 11:03 PM
78fordman's Avatar
78fordman 78fordman is offline
78fordman has a good reputation on FTE.78fordman has a good reputation on FTE.78fordman has a good reputation on FTE.
Get a pressure gauge and t it in. That is the best way to determine hg failure.
Sent from my leash using IB AutoGroup
Old 04-03-2014, 06:21 PM
I have just stumbled across the recommendation that the coolant level be kept at the minimum mark on the degas bottle. I have been keeping it at least halfway between the two or a little closer to the max level. Now that it has puked some out, I am going to hook up tomorrow and stress it again and see if it continues to puke. Maybe this is why I am not getting any other signs of failure. Grasping at straws I know, but...
Old 06-26-2014, 01:44 AM
Wheatted Wheatted is offline
Wheatted is starting off with a positive reputation.
Bismic - that was an informative systematic description. Thanks for starting the thread. I will be referring to it again. Do you know if there is such a description on performing the coolant flush (pre-work on EGR Delete) on this website? Why is this so important as I have seen it recommended by others?
Oh oh. Found the cooling system flush too. Thx.
Wheatted
Last edited by Wheatted; 06-26-2014 at 01:53 AM. Reason: Noticed answer in different thread
Old 06-26-2014, 02:29 AM
Yahiko's Avatar
Yahiko Yahiko is offline
Yahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputationYahiko has a superb reputation
You want to make sure to do the flush before you replace an oil cooler.
UNLESS it has failed. Coolant and oil are bad juju. If you only have a bad EGR
cooler the "BEST" way is replace the cooler and do the flush then do the oil cooler.
The oil cooler acts like a filter and all the crap that a flush kicks loose will plug
up any cooler. that is why if you can plug the old one up and toss it.
Sean
  #28
Old 06-26-2014, 02:10 PM
Bordeauxman Bordeauxman is offline
Bordeauxman is starting off with a positive reputation.
Where can I find this: Snap-on RADKITPLUSA 078-00592 and what exactly does it do?
  #29
Old 06-26-2014, 04:07 PM
Yahiko's Avatar
Does not have to be a Snap-On tool.
Any vacuum assist fill tool will do the job/
What it does is put the cooling sustem into
a vacuum by way of a Venturi in the line.
Then you open a valve that goes to a bucket
of what you putting in. The big thing is when
under a vacuum any air bubble is expanded and
when you remove the vacuum it shrinks and that
way you have less trapped air in the system.
Sean
  #30
Old 03-23-2015, 12:51 PM
fireman660r fireman660r is offline
fireman660r is starting off with a positive reputation.
I did an egr delete and new oil cooler a month ago. Here are the stats of recent repairs, replacements; New radiator 5 weeks ago (tech diagnosed egr cooler and broke degas nipple on radiator, so I got a new one free), replaced oil cooler and installed egr delete from IPR a month ago. Did coolant flush prior to work, vc9 flush then water flush, then open block drains flush while engine running. Installed IPR full flow coolant filter from egr delete. Replaced coolant with Peak ELC silicate free Final Charge. Mixture was a little strong on coolant. Dumped 3.5 gallons of coolant in, then topped with distilled water. Has ran fine last month with no issues running Spartan aggressive street tune. Several WOT and no issues, normal driving deltas are 5-7* I had an oil cooler fail 100k miles ago and had heads pulled and checked for warp and installed studs then. Yesterday I pulled a 4k lb gooseneck trailer empty on the aggressive tune for 25 miles with no issues, then put a polaris Rzr on it and went 40 miles on a heavy tow tune and puked. Pulled back home later and puked again. Coolant never got over 220*, I heard the fan ramp up when it did get that high and pulled it right back down. Highest I saw the oil temp go was 231* it was usually 10-15* of CWT. Boost never appeared to go over 22PSI. I also have a new cap on bottle. I am curious if it was bad cap. Lost about 1/3 gallon of coolant. I have 10k lb fifth wheel to pull all summer. Puking has been a problem for most of the time I owned truck, and honestly I never got worried about it. I regularly check oil for coolant or fuel and have never seen traces of either, I change oil every 5k miles like I am supposed to, and change fuel filters every other oil change. I think due to my over babying of truck I don't see some of the issues that might be at play. Any suggestions would be appreciated. Thanks
Recommended readings - Temperature and Pressure bismic 6.0L Power Stroke Diesel 104 01-01-2017 01:20 PM
Radio Speaker Wire Codes - 1994 F150 John1994F150 1987 - 1996 F150 & Larger F-Series Trucks 1 02-09-2016 04:43 PM
Relationship between ICP pressure and voltage bismic 6.0L Power Stroke Diesel 23 07-23-2014 09:35 AM
79, 302 Compression test #'s DLOW79 1973 - 1979 F-100 & Larger F-Series Trucks 1 09-12-2011 08:43 PM
First Rotella T6 UOA bismic 6.0L Power Stroke Diesel 14 10-17-2010 07:41 PM
Tags
1997, 350, antifreeze, coolant, cooler, degas, deleted, egr, f250, ford, ground, leaking, system, troubleshooting, work
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
