You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
As the title states...
If you found an interesting or cool or rare part for your van and installed or are using it, Brag about it here! And make us drool.
OK I'll start off:
Pics will do my talking
And
Now to find a panel for the inside...
__________________
Rob.
Ford-less at the moment...
Not from a junkyard...... but if I hadn't bought 'em, they would of ended up crushed!
1980 E150 custom van parts.
standard transmission (3 speed+OD on the floor) shifter assembly, trans. cross member, steering column with clutch/brake pedal assembly, and great running 60k miles 300-6cyl engine!
All for 150$
However, these aren't in use......yet.
__________________
1990 Ford F250 4x4, ZF5, L/S 4.10, N/A 7.3L Diesel, 568,808km/377,497 miles, still on the original clutch!
1989 Ford F150 300-6, C6, 2.73, 127,000km/79,000 miles.
1987 Ford E350 26ft. Motorhome, N/A 6.9L Diesel, C6, 3.54, 265,000km/166,000 miles.
1985 Ford E350 Ext Van, 6.9L Diesel, C6, 4.11, 658,000km/411k miles
i've had several good finds, but i'll only post the ford-related ones here
for a ford 300-6, offy DP intake plus headers and carb. i still have a truck i could put it on, but probably never will. PM if you want it
for the van, tons of built-in toolboxes and cabinets, i should post pics one of these days
auxilary rear heat unit, came from a conversion van, now lives just behind the drivers seat against the wall. i had to trim some corners off its body to fit it between the toolboxes and the pillar, right along the outside wall
oh, and to top it all off, i found a way to keep my bolt bin overflowing
Picked up a never used Sprinter 3 person bench seat on Craigslist on the weekend for $60! It's going in the first row position as soon as I find floor brackets.
My 02 E-150 Solar Eclipse has some nice factory alum road wheels and I found a (NOS) set of center caps on eBay for $78.50. New Mich XL tires, caps and a good coat of wax there looking pretty good, but Crutchfield got me for six Kenwood speakers.... eBay counts as a junkyard.....LOL
I does indeed count---I dare say its one of the biggest, easiest to shop and sometimes not bad prices too. Of course there's a reason its nicknamed "fleabay"!
Speaking of the E-Series rear heater/AC units---I just bought a brand new, in the box unit, never used shipped to my front door for the staggering sum of $149! The one or two I've seen in scrap yards weren't worth removing!
Now just try to get your hands on the AC and Heater lines for that unit at a reasonable price
Oh yeah---already hip to that mess!
Actually I've fitted my existing van with an overhead mounted aftermarket heater so those lines are easily enough run and installed. The A/C lines will never be connected since my cargo needs only heat---its fine at summer temps.
If I were to run the rear A/C though I think I'd need a new compressor line set with tee fittings for those lines----not something I want to do at this point!
