water pump repair (y-block) - Ford Truck Enthusiasts Forums
Old 03-16-2012, 03:25 PM
Stephen67's Avatar
Stephen67 Stephen67 is offline
Stephen67 has a good reputation on FTE.Stephen67 has a good reputation on FTE.Stephen67 has a good reputation on FTE.
Anyone tried one of those water pump repair kits?
Water Pump - New - Ford 272, 292, 312 V8 Only - MAC's Antique Auto Parts
Or am I better off buying a new one?
Spent a couple hours tuning up my engine from that stupid accident only to find I'm pouring coolant out of the top hole on the water pump. grrr...
Old 03-16-2012, 07:53 PM
Stephen67's Avatar
Anyone?
Mine looks a little different than the ones I'm finding, not sure if I can bolt the fan bracket on the same.
Old 03-16-2012, 08:54 PM
pintoplumber pintoplumber is offline
pintoplumber has a good reputation on FTE.pintoplumber has a good reputation on FTE.
I have a car engine in mine. My understanding is the truck water pump had a bigger snout for the fan. I'd bet the parts inside for a rebuild kit would be the same. Dennis
Old 03-16-2012, 09:11 PM
ibuzzard's Avatar
ibuzzard ibuzzard is offline
Gone But Not Forgotten
ibuzzard has a great reputation on FTE.ibuzzard has a great reputation on FTE.ibuzzard has a great reputation on FTE.ibuzzard has a great reputation on FTE.
Quote:
Originally Posted by Stephen67 View Post
Anyone tried one of those water pump repair kits?Or am I better off buying a new one?
You're better off buying a new one.
Old 03-16-2012, 09:31 PM
Stephen67's Avatar
Thanks for the input, I think I'll have to order a repair kit as I have a 272 HD and mine looks a little different and I don't think the fan part will bolt the same.
Old 06-12-2014, 10:39 AM
Outlaw56 Outlaw56 is offline
Outlaw56 is starting off with a positive reputation.
Stephen,
So did you get a kit and how did the rebuild go?
Old 06-12-2014, 12:09 PM
FortyNiner's Avatar
FortyNiner FortyNiner is online now
FortyNiner is a splendid one to beholdFortyNiner is a splendid one to beholdFortyNiner is a splendid one to beholdFortyNiner is a splendid one to beholdFortyNiner is a splendid one to beholdFortyNiner is a splendid one to beholdFortyNiner is a splendid one to behold
Quote:
Originally Posted by Outlaw56 View Post
Stephen,
Stephen is taking a break from the forum and is unlikely to respond. I had an I6 pump rebuilt through Rock Auto and was very satisfied. There are not any kits available for that version from my search.
Old 06-12-2014, 12:26 PM
Thanks 49er. I have three of the 3/4" shaft pumps laying around and if they are not difficult to rebuild, I was going to put kits in them just to have them ready for who ever ends up with my trucks. I was especially interested in process of removing the pulley hub and how to get it back in the same position it was installed. Pretty difficult if not impossible to find the rebuild kits huh?
Old 06-12-2014, 12:35 PM
ibuzzard's Avatar
Last activity: June 1, 2014
Old 06-12-2014, 03:26 PM
FortyNiner's Avatar
Can't speak to the V8 version - the I6 kits and replacement pumps are ghosts: rumors but no real sightings. It is one of two parts (the thermostat housing the other) that aren't reproduced, by my experience. I've found another pump core that will be rebuilt as a spare. Good luck with your mission.
Old 06-12-2014, 03:54 PM
Thanks, good luck on yours too. I will keep my eye out for a donar I6. Thats a 239?
Origins for my Y-Block?? Any ideas? brit_wheels_fan Y-Block V8 (239, 272, 292, 312, 317, 341, 368) 15 01-06-2017 01:41 AM
RIP Mac's DB429SCJ 1973 - 1979 F-100 & Larger F-Series Trucks 13 06-12-2016 07:13 PM
Kingpins - Metal or Nylon bushings?? Death_Eagle_571 1961 - 1966 F-100 & Larger F-Series Trucks 12 04-26-2015 06:54 PM
Oil pump leak/rebuild kit 63' f100 1961 - 1966 F-100 & Larger F-Series Trucks 26 04-07-2011 12:47 PM
1955 Ford F100 Engine Swap Astortts Engine Swaps 7 08-09-2004 12:07 AM
Tags
289, 292, block, ford, kit, pump, rebuild, repair, replacement, truck, water
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
