C4 to AOD swap
Old 03-16-2012, 12:44 PM
granny_rocket's Avatar
granny_rocket
granny_rocket is offline
C4 to AOD swap
My truck has what I think is a c4 transmission. '84 4x4 and 302 engine.
How hard (I've done plenty of transmission swaps before just not on fords) is it to swap in an AOD trans? What parts do I need? I'm sure the bell crank is different but how will the AOD bolt in? Do I need a different x-member/mount? How about cooler lines, throttle valve cables or the transfer case. Were there different model AOD trans cases for the 4x4? I want to start searching now for one and all the necessary parts to do the swap. Any electronics I need to worry about? The truck is completely electronic less (sans ignition system).
Thanks!*
Old 03-16-2012, 03:13 PM
smashclash's Avatar
smashclash
smashclash is offline
Where in South Jersey are you?
Old 03-16-2012, 03:52 PM
granny_rocket
Glassboro. Just outside Philadelphia
Old 03-16-2012, 04:20 PM
Franklin2's Avatar
Franklin2
Franklin2 is offline
Received 1,679 Likes on 1,356 Posts
Your truck more than likely has a c6 transmission. Good luck finding a good used AOD, most all will need freshening up with a kit.
If you get this piece meal, it's going to cost you. Your best bet is to buy a donor truck and get all the stuff off it. You could put your old tranny in the donor and sell it. Your biggest problem will be the throttle linkage to the AOD. It has to be correct for the tranny to operate correctly and last.
Gary Lewis's Avatar
Gary Lewis
Gary Lewis is offline
Posting Legend
Used to live in Kennett Sq. Anyway, I doubt you have a C4 as I didn't think they put them in 4x4. But, I may be wrong. Doesn't matter too much as the AOD bolts in where the C4 and C6, which I think you have, go. But, why do you want to put an AOD in there? They are considered by many on here to be light duty unless built up a bit. So, depending on what you are going to do with/to the truck that may not be the best choice.
Old 03-16-2012, 06:53 PM
smashclash's Avatar
smashclash
ahhh, my neighbor. I got my MBA at Rowan and now live in Gloucester Twp near Camden County College.
Old 03-17-2012, 12:51 PM
klricks's Avatar
klricks
klricks is offline
Thanks!*
The TV cable must be done right else you will burn up the AOD in a few miles. Lurk in some of the Mustang forums and/or carb sites to find out how and what adapters or carburetor is needed.
Old 03-17-2012, 11:28 PM
81ChopTop's Avatar
81ChopTop
81ChopTop is offline
In the first year or two of the AOD, kick-down rods were used. You could go with that, but it's a pain to find the correct one.
dlong950
09-04-2010 09:47 AM
northeaster79
01-16-2010 09:29 AM
johnarahill
1978 - 1996 Big Bronco
08-02-2007 02:47 PM
witdog2020
01-09-2006 07:47 AM
pfogle
General Automotive Discussion
13
11-19-2005 09:51 PM
Quick Reply: C4 to AOD swap
