Rudamentary A/C repair questions
#46
#47
R134a and R12 run similar pressures with R12 being a few psi lower. When you do a retrofit it does not require changing the switch. So what ever switch is called for will be o.k.
The problem with putting a bigger capacity compressor into a system without changing to the corresponding condenser and evaporator is the condenser will not have enough cooling capacity, increasing discharge pressure and possibly sending vapor o the expansion device(orifice tube) which in turn increases evaporator pressure(suction pressure) If anything you want to oversize your condenser so you will have increased sub cooling on those hot days. This is why the high efficiency house units have such large outdoor condensing units, the extra subcooling.
Matt
Matt
#48
#49
Are you adding the electric fan as a pusher just for the a/c condenser? If you are removing your mechanical fan that one little electric will not be enough. You would have to find out the capacities of your replacement condenser and compare that to the original condenser to know if you have a large enough condenser for your compressor application
matt
matt
#50
75_92_95
07-22-2019 11:49 AM
lippsenator
06-19-2009 03:02 PM
