'91 F700 429 is done! What would it take to run a 460? - Page 2 - Ford Truck Enthusiasts Forums
Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
Old 05-16-2012, 01:40 PM
cj06's Avatar
cj06 cj06 is offline
cj06 is gaining momentum as a positive member of FTE.
dumb question ?
did you prime the engines oil pump first with a drill before starting it up ?
Old 05-16-2012, 05:37 PM
rotun's Avatar
rotun rotun is offline
Reads ***** rules!
rotun has a good reputation on FTE.rotun has a good reputation on FTE.
Yes and thanks for having my back on this as I'm sure not everyone knows to do that. Actually got about 20 miles out of it, the mains were not torqued to spec and I was lazy and didn't check the rod caps but I damn sure will when the replacement gets here as well as take video with my GoPro so I can send it to the builder showing the torque values.
Old 05-31-2012, 11:50 PM
rummur s.c.'s Avatar
rummur s.c. rummur s.c. is offline
rummur s.c. is gaining momentum as a positive member of FTE.
thats a great use for a gopro.. Perfect for contract work..
460 Complete Overhall with pics *Finshed Update !! 1-4-2011 Last Page! Big-old-460 1987 - 1996 F150 & Larger F-Series Trucks 314 09-21-2016 10:38 PM
Diagnosis please...Injectors pulled to replace Orings ........ rotun 1999 - 2003 7.3L Power Stroke Diesel 65 04-30-2014 01:51 PM
351w Build-up 77f100guy Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 12 07-19-2010 08:37 PM
Post your air compressor install pics rotun 1999 to 2016 Super Duty 34 05-07-2010 09:31 AM
my stump puller 86bigred 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 8 07-30-2009 12:45 AM
Tags
429, 460, 91, air, axles, code, engine, f700, ford, ilder, motor, supercharged, swap, vs, wheels
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
