Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > 1997 - 2003 F150
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
1997 - 2003 F150 1997-2003 F150, 1997-1999 F250LD, 7700 & 2004 F150 Heritage SPONSORED BY:
  #1 (permalink)
Old 03-16-2012, 09:13 AM
cixelsyd cixelsyd is offline
Garage is empty, add now
cixelsyd is starting off with a positive reputation.
97 4.6L Water Pump Leak
About 14 months ago I noticed a bit of antifreeze under my 97 4.6L. I took it into the rad shop as I had the rad and heater core replace a few years back and wanted to make sure it wasn't a problem with those. The pressure test indicated that the leak was coming from the water pump. The leak appears to be dependent on the outside temperature as I only notice coolant loss in the winter months.
This winter the loss was more pronounced, but I have not noticed any further loss now that spring has arrived.
Is this common to these vehicles?
Should I just change the water pump anyways>
  #2 (permalink)
Old 03-16-2012, 10:06 AM
kidzstang kidzstang is offline
kidzstang is starting off with a positive reputation.
If it were me, and it ain't but if it was, I would change the water pump. The leak will progressively get worse and the water pump will ultimately fail spewing coolant through the relief hole. Most likely this will happen when you are all dressed up heading to a wedding or some fancy doings.
The job is easy and the part is cheap enough.
__________________
Jack
  #3 (permalink)
Old 03-16-2012, 11:17 AM
Papa Tiger's Avatar
Papa Tiger Papa Tiger is offline
2011 Ford F-150
Papa Tiger has a good reputation on FTE.Papa Tiger has a good reputation on FTE.
Change the pump for sure and probably the thermostat as well and the hoses and belt. It's time and if you don't they will put you beside the road some lonely rainy night down the road fore sure.
Tags
1997, 46, 46l, 6l, 97, f150, ford, housing, leak, liter, pump, ranger, thread, truck, video, water
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
