8 lug turbine or jackmans wheels
seeing this stuff makes me warm inside
makes stuff like this happen:
73 f250 highboy in a little mudhole - YouTube
i love it
i love it
WOW you lucky dog, you will probable have to go to a reputable tire&wheel place.
Cause you will need the long skinny collar shank to fit inside there and a pressure type washer?
I hear on these aluminium rims getting the lug nuts to stay tight it a constant battle, so FYI spent the $ and get a good quality set. Yea I know thats 32 lug nuts and some sort of constant friction washer x32.
When alum and steel are matted together its dissimilar metal so corrosion is common, put a little grease on the back side of the wheel hub area and anti siez on the threads.
Let us know what you get worked out ok? Thanks fellow fin rim owner....
You got my attention
Ok, You got my attention. Where you at and how much for the turbines???? and for the slots??? let me know, Kenny. fordaholic69@yahoo.com
Well here you go and I have the other 3 to match the fins and slots in the pic and I have a set of the Jackmans and alum spokes......sorry no pics. Pay no mind to the HUMVEE bead lock and the ol white spoke.
And thats 1 of 4 of a BFG AT 35x12.50x16.5 and there are a set of BFG MT's 16.5 in the barn too.
Craigslist-a-holic, why yes I am.
And I'm looking for you to there a set of rims 73ferd.
Cragar Style Mag Lug Nut 7/16"-20
Cheap and they work great
I have a set of turbines and a set of slots here, I found the lugnuts for them at Amazon actually, had some on closeout and got most of them for under a buck apiece with washers so I'd check there for sure.. I'm not using these rims so if you find you need some I'd let them go reasonable.. I just don't know how to put pictures here..
You will need the nuts with a .740" diameter shank. I think I used a 1 inch shank, I could measure them I guess but measure your rim thickness and go from there. Or I needed the ones with that size shank anyway, the smaller ones just would not fit tightly in the rim. I think its the same size as your average 9/16 stud lug nut McGaurds # is 62820.. spendy at Summit though
#29
Not mine. Comes with lug nuts also. I know they are only 5 lug, but I'm sure 1/2 ton people are checking this thread out also.
15x7 Ford Jeep Turbine wheels Rims 5x5.5 Suprior CJ F150 truck 39-578X Superior | eBay
Uploaded with ImageShack.us
#30
csquire69 here you go, be setting down when they tell there prices. lol
AKH Vintage Wheels - Ellensburg Washington
